This is a prop I built for a Star Wars party. I didn't want to spend a lot, but I did want it to look cool.
I know that there are some incredibly talented folks who put years of effort into making awesome R2D2 and other droids, but I wanted something inexpensive and I only had a few months until the party. So rather than use sheet metal and fiberglass, I used mostly cardboard and wallboard joint compound. I also use a lot of stuff that I had in my junk-box.
Yep - that was once a used refrigerator box!
Remove these ads by
Signing UpStep 1: R2D2 frame and covering
Google image search is great!
Here's a site that I found very useful: (especially the Autocad .DXF files)
http://files.astromechbuilder.com/attachments/?dir=/*2003_Archives/9-September_2003
also:
http://starwars.wikia.com/wiki/File:ArtooBlueprints-SWBTUC.jpg
I acquired a few refrigerator boxes at a local retailer and got to work.
I created a frame for the body, then wrapped the cardboard around the frame.
This is a bit tricky. You'll need to soften - but not drench - the cardboard by spraying it with water and letting the moisture soak through the layers. When it's sufficiently soft, you're ready to wrap it around the frame. Apply hot glue to the edges of the frame and attach the softened cardboard sheet to it. I recommend that you get some assistance with this step.
It has a few inconsistencies, but we'll compensate for that later.
Visit Our Store »
Go Pro Today »
look for the .DXF (AutoCad files) that start with the prefix JAG200
Thank you for you attention, and sorry if I am being a drag.
does putting people down make you feel better ?
maybe you didn’t realise you were putting that person down but you most certainly were
This IS the droid we've been looking for.
Then coat the whole thing with paper mache or the wall joint stuff and paint.
try; http://astromech.net/
The 3rd leg astromechs have needs to retract in order to fit inside the slot in the back of a starfighter.
After your done, you use paper mache to smooth out the surface and then you paint the design.
A couple of people have mentioned bowls, which I don't think are going to be the right shape, but perhaps hemisphere baking pans would work? They come in a variety of sizes, and are perfectly round hemispheres. It's what bakers use to make planets, baseballs, etc.
now back to reading this "fresco frijoles" 'ible.
Later seeing that the head can be removed, you could do either or both of the following:
Use a PICA Laser Projector (Small enough to fit in your hand.
Add a small motor with a wiper blade motion, it would add that something extra.
Thanks for sharing your BUILD
JSF_QLD
Just love it. It's a great prop and I want one :)
With the head maybe a stainless steel bowl could be used. But since the head is not just half a sphere it probably would'nt work without a lot of tweeking. One thing that comes to mind would be to make the basic paper mache head as you did, just less paper and foam. Then use a nail in the top centre with cardboard template attached. You slap on the jointing compound and spin the template around slowly to form the final dome. Think I saw an 'ible for making circular 3D objects this way.
Hint for silver spray paint, always put a coat of clear over it. Otherwise the silver always rubs off. If you use auto spray paint, it's more durable but doesn't look shinny unless you clear coat it
About R2D2's third leg - In the original movie they had two R2D2s. One was a remote controlled version with the third leg to stop it falling over when it moved. Notice how it's always leaning at a backward angle. The other had only 2 legs and a small person in it to do the side to side walk and shaking scenes. It's always upright.
Jawa Jaka and R2-AL
http://r2-al.blogspot.com
Such a classic 'droid, I'm sure you'll use it many times.
Adding wheels to the legs and the base of the body could make it movable.
Just spraying cardboad with varnish will stiffen it. But wont add to strength, for that u need cloth reinforcing. Yep it will work with varnish as well as glass, though cheaper.
Cool 1 dude; Kiwi
Kewl instructable
that looks really good man.
If i may be so bold as to make a suggestion...
I reckon it could look better if you used some extra bits of cardboard/metal/junk for body detailing so that it has a bit more depth to it and maybe cut some bits out for that crazy 3D effect the kids seem to love these days.lol
Pretty hard to do after its made maybe but if anyone else gives it a go something to think about.
Really cool though for just a cardboard build. Great job!
E.V.
but i agree on you he did do an awesome job
