Fully Automatic knex Gun !! ( it really works )
 by anres321
Hey guys
this is my fully automatic knex gun it shoots about 15 feet and it is really fully automatic !!
Step 1: The trigger
make 2 of this
1-40 of 55Next »
LvNo1000 says: Apr 24, 2013. 8:32 PM
:D I tried this awhile ago. *high five* for perfecting it
JonnyBGood says: Oct 10, 2012. 7:38 PM
I am making something similar to this but with a different mech... Your clip looks like it works better than any I have built for white rods so, if you don't mind, I'll borrow it.
anres321 (author) in reply to JonnyBGoodOct 14, 2012. 2:47 PM
sure bro, no problem :)
JonnyBGood in reply to anres321Oct 14, 2012. 3:40 PM
It worked a lot better! I just didn't use the clip pusher thing. I made a hinged lid to it.
instructaguy says: Jan 15, 2012. 7:59 AM
make a bigger mag, then make it handheld, then it will be too good and can you make a version without the big wheel and the massive motor. i have the red box connected to the motor ,and the grey ones. so plzzz plzzz make.
anres321 (author) in reply to instructaguyJan 16, 2012. 11:35 AM
instead of the big wheel you can also use the smaler wheel and a normal wheel 2 times,, the mag is pretty easy to mod, just make a copple of mags and put them on top of each other :p
instructaguy in reply to anres321Jan 19, 2012. 7:47 AM
im gunna use a small wheel and make it a bit smaller, thanks.
anres321 (author) in reply to instructaguyJan 19, 2012. 8:33 AM
cool, the wheel is used for making the motor slower and much stronger so if you use just one small wheel it will probably not be strong enough. but you can always give it a try, this is just a concept for an automatic firing mechanism so go ahead and make it better !
instructaguy in reply to anres321Jan 18, 2012. 11:59 AM
yeh thanks for the reply i might make and i can make it a bit smaller, thats really inspired me.
instructaguy in reply to anres321Jan 18, 2012. 11:51 AM
thanks man im glad i subscribed your really helpful
stormrunner18 says: Jan 15, 2012. 3:42 AM
BEAST!!!! man!! maybe you could mod it to make the base stabler?
The Cannoneer says: Oct 28, 2011. 1:50 PM
for some reason the magazine wont connect
anres321 (author) in reply to The CannoneerOct 29, 2011. 2:35 AM
you have to connect them with the y-connectores, be sure they are all on the right place :p
The Cannoneer in reply to anres321Oct 29, 2011. 12:54 PM
i tryed that....the y connector on the right(pic 5) goes in but the other doesnt
anres321 (author) in reply to The CannoneerOct 30, 2011. 3:18 AM
Sorry man but i really cant see your problem. i could try to solve it if you post a picture...
TheAwesomestDude says: Aug 5, 2011. 2:43 PM
cool
ygeny says: Jul 18, 2011. 9:29 AM
sa ne marche pas moi
anres321 (author) in reply to ygenyJul 19, 2011. 4:11 AM
qu'est ce-qui ne mache pas ?
knexinglemon says: Jul 1, 2011. 8:24 PM
can you do it without that big gear because i dont have one of them??
anres321 (author) in reply to knexinglemonJul 15, 2011. 7:30 AM
I'am sorry for reacting so late but I was at vacation and was not able to go on the internet for 2 weeks :p the big gear is used for slowing down the motor and giving it more power,, if you switch the two gears your motor will be a lot faster but have less power :D you can do it with a small gear and an average gear but the motor will probably be to fast and will not have enough power but if you repeat that i think it will work so i mean - small gear -> bigger gear + small gear -> bigger gear
super knex builder says: Jun 30, 2011. 5:45 PM
I don't understand the push pin
anres321 (author) in reply to super knex builderJul 8, 2011. 11:03 AM
the pushpin is just for pushing the bullet out of the gun,, if you dont understand the mechanism you must be more precise
super knex builder says: Jun 25, 2011. 5:09 AM
errrr! I cant get all the peices on right!
anres321 (author) in reply to super knex builderJun 25, 2011. 8:49 AM
which part cant you get on ? look at the pictures first and then try to figer out which part you want to make first,, you dont have to make it in order.
super knex builder in reply to anres321Jun 25, 2011. 10:17 AM
I can't get the magezine on
anres321 (author) in reply to super knex builderJun 26, 2011. 1:21 AM
look at picture 4, the first picture. at the top of that picture you can see 2 blue connectors. that is where you have to attach your mag,, in step 5, the 5th picture you can see 2 Y-connectors they have to be connected at the blue connectors.
I hope this helps
Abcwtfidontcare says: Mar 4, 2011. 4:17 PM
Switch around the big gear with the small gear for EXTREME speed.
anres321 (author) in reply to AbcwtfidontcareMar 5, 2011. 4:31 AM
yes sure, I know that !! buy first of al you'll need about 100engines to do that and then he'll still have not enoug time to put in a new bullet :D and all your knex will be destroyed
Knexman15 says: Feb 24, 2011. 7:23 AM
is it a catapult? i can not tell
anres321 (author) in reply to Knexman15Feb 24, 2011. 8:02 AM
no :D its just a weird looking gun but I didnt spent much time at the design, The system is more inportant to me XD
michiel123456789 says: Nov 8, 2010. 10:11 AM
Very Clever!!!
anres321 (author) in reply to michiel123456789Nov 9, 2010. 1:11 PM
thx !! :)
DJ Radio says: Jul 5, 2010. 3:20 PM
This looks like one of the knex semi-autos a KI'er made a few years back. You need to give credit for the mag.
Knex_Gun_Builder in reply to DJ RadioAug 27, 2010. 10:21 AM
WHO CARES!!!!!!!!!!!! ??????????????
Dirtyboyy in reply to Knex_Gun_BuilderOct 25, 2010. 7:14 AM
i !!!! LOL
~Aeronous~ in reply to DJ RadioJul 7, 2010. 8:20 PM
Me and Visper made that mag when we where trying to make a mag which would fit a block trigger, and put it on the TR!
Sketch98 says: Jul 17, 2010. 11:36 AM
Only 1 problem, doesn't look much like a gun
H1T4TCH1 in reply to Sketch98Aug 26, 2010. 8:21 AM
that isn't a problem, that's a con.
knexsniper123 says: Aug 21, 2010. 6:01 PM
it dosent work
anres321 (author) in reply to knexsniper123Aug 23, 2010. 8:26 AM
why not ? mine does work, I know it doesn't shoot that far but it does shoot
1-40 of 55Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
