Introduction: Fun Flower Gate
Picture of Fun Flower Gate
This is an expansion upon the fun flower fence instructable. https://www.instructables.com/id/How-to-make-a-Fun-Flower-Fence/
When I was out of town a few months ago, my wife surprised me by building a gate for our picket fence. She told me on the phone that she did this. She is actually a good woodworker, so I was expecting something pretty nice. Surprise! The gate was a pallet that was painted yellow and attached with hinges. It was big and heavy. But, it was a gate, which we needed for our dog (now 2 dogs). I have waited a respectful amount of time and now I am ready to fix the gate.
If you like this PLEASE vote for me. I really would like to win a camera so I can stop borrowing one to post instructables.
This instructable  respectfully submitted to the Instructables Sponsorship Program by Eukaliptos.
Step 1: Materials and Tools
Picture of Materials and Tools
Materials
Wood
Paint
Exterior screws
Hinges
Tools
Table saw or radial saw  (You can skip this if you are using pallet wood and tying it to another fence)
 Band saw, Scroll saw or jig saw to cut flowers
 Rotary tool or wood carving knife
router
Paint brush
Step 2: Cut Stems
Picture of Cut Stems
You can use pallet boards without cutting them. Or you can cut the stems from whatever wood you have. The width can be anywhere from 2-4”. Choose the height that you would like for your flowers. Mine range from 3 1/2- 5' tall. On this gate I am varying the heights of the flowers to come to a point at the center
Paint them green, unless you would like some other color stems.
Step 3: Cut Flowers
Picture of Cut Flowers
Trace a flower design on the wood.
If you are making a complete fence, it helps to cut out a template for the flower out of hardboard. You can paint the template and drill a small hole in it to decorate your shop space.
Cut out the flower. I cut into tight corners with my band saw to avoid binding the saw blades on the flowers curves (see pics).
After you cut out the flower shape, round over the front edge of the flower with your router.
The next step is to carve out the flower details with the dremel rotary tool. The flower here has very basic details, you can carve them more intricately if you want.
Step 4: Paint Flowers
Picture of Paint Flowers
I paint the centers of the flowers first. Then I cover the center with a jar or bottle cap and paint the petals. You can add highlights and details to the petals if you like. I don’t bother with primer and I haven’t had any problems with them.
Step 5: Leaves
Picture of Leaves
Cut and paint leaves using the same techniques you used on the flowers.
Step 6: Attatch Flowers to Stems
Picture of Attatch Flowers to Stems
Find exterior screws that are just a bit shorter than the thickness of your flower and stem stacked together.
Pre-drill the holes for the screws. Screw the flower to the stem through the back of the stem. Use two screws in the flowers for strength and to avoid spinning the flowers.
Do not attach the leaves yet.
Step 7: Make a Z Frame
Picture of Make a Z Frame
Make a Z shape for your gate. I used 2X3” boards, though typically gates are made with 1X4” boards, I used what I had and you can too.
My gate is 32” across I spaced the boards so they would look okay with the existing fence. After placing the two cross pieces where I wanted them I laid the diagonal board in position. Then I marked the position of the cross pieces so I could make the cuts. After, making the cuts, I redid them a second time bit neater, oops.
Then I placed the diagonal board in position and pre-drilled holes for the screws.
This is all that you need for a normal gate. But, here I don’t have access to gate hinges, so I am using 3 inch hinges. I decided to add a support piece for the hingesas shown in the photos.
Step 8: Place the Pickets
Picture of Place the Pickets
I placed the two end pickets first. Then I just placed the other pickets on the frame until I was happy with the look.
I placed the leaves on the gate. Then I lifted up each stem, while holding on to the leaves and pre-drilled and screwed the leaves on to the stem from the rear.
The pickets are then predrilled and screwed down to the frame.
Some of the flowers could only be screwed in one place because of the frame and where the flowers were. To secure these flowers, I flipped over the gate and pre-drilled and screwed the flowers and/leaves to other flower stems from the back side of the gate.
Step 9: Attatch the Gate to the Fence
Picture of Attatch the Gate to the Fence
I screwed the hinges in to the fence post.
Admire your new gate!
PS…Get ready for requests for gates. While installing mine, I received 3 requests for gates.
Aiesas (author)2013-07-21
Really admire.. After move to our new house last year.. We dont have budget anymore for the gates. This really great idea!! We can Just DIY. Thanks and voted :)
artlife (author)Aiesas2013-08-12
Thank you. This was a really inexpensive option for us, as it could be made with scrap wood and stuff I would pick up off the side of the roads.
good luck.
Luny (author)2013-07-06
I LOVE THIS!!!!!! I was given a scroll saw that I think would be perfect to cut out the flowers - not sure as I've never used it.
One suggestion - when you paint the flowers, instead of using a bottle cap to cover the center, use the bottle cap to create a stencil out of wide painter's tape. Simply draw around the cap, then use an Exacto knife to cut out the circle. This way you can use the cut tape to get a clean edge, and use the cut out circle when you paint the petals to cover the dried center. The tape will stay in place much better than the bottle cap.
You have my vote!
artlife (author)Luny2013-07-06
Thanks! A scroll saw would be perfect for this project. Use a coarse blade to make the cuts faster.The tape is a good idea. The bottle cap and for larger flowers jar lids work for me because they fit into the groove that has been carved for the flower center. That way paint doesn't seep around the edge quite so much. Also when it sits in the groove it doesn't slip around very much.
About This Instructable
3,369views
80favorites
License:
More by artlife:Kid's fishing gameGiant Four Across or Connect Four gameKids wooden tool set UPDATED new tool
Add instructable to:
