Fun Prank in any Windows Version by SilentZoom
An extremely entertaining prank to play on unsuspecting friends (or enemies) by exiting the Windows Explorer process, causing the task bar and any Explorer windows to disappear.
Note:This CAN NOT and WILL NOT cause any harm to the victim's computer. If you encounter any troubles, just restart the computer. Any damage caused as a result of trying this out is neither my FAULT nor my RESPONSIBILITY. Any damage caused is your fault, due to incorrectly following these steps (and your computer can befall harm if you exit certain system-crucial processes). This process is harmless.
Step 1: Open Windows Task Manager
After gaining access to the victim's computer, open Windows task manager. This can be done two different ways:
1. On MOST Windows XP versions (and previous versions of Windows), press ctrl-alt-delete to open task manager.
*On some computers, the administrator may have changed that function to leave the desktop, and open a window that has a couple different functions, such as shutting down the computer, simply select the open task manager button, or, if this doesn't work for you try the Vista steps.
2. On ALL Windows Vista versions, press ctrl-shift-esc to open task manager. (You can also use ctrl-alt-delete and then select open task manager.)
**Important Note: On some systems, the administrator may have disabled Windows task manager. I have found that this isn't the case on most systems (the only example I can think of are the public library computers, locked down to browsing the library's online database). If this IS the case, you will get a "the administrator has disable windows task manager" error.
3. Now that you have Windows task manager open, navigate to the "processes" tab, as shown in the picture.
admin says: Aug 5, 2008. 10:56 AM
Hello, and welcome to the Instructables community! It's great that you've decided to tell the world about something you've made by publishing an Instructable. We just wanted to let you know that your project still needs a little more work if you want it to be well received on Instructables. Projects that don't include certain basic elements tend not to get the attention that they deserve, and so we'd love for you to check out the list below of what makes a successful Instructable. Successful projects on Instructables include: - clearly written details of a finished project with instruction - as many steps as are necessary to explain your project - clear images that you took of your project for most, if not all of your steps - an intro image - proper spelling and grammar - appropriate cautions or safety considerations I'll give you another opportunity to make any final changes to your project before we publish it. Once you're all set to go, please republish your project and send me a quick comment letting me know that you've made some changes. I'll give it a quick final check to make sure you're on the right path, and then remove this note. Thanks for your submission and we hope to see your project published soon!
LiquidLightning says: Jan 13, 2011. 11:58 PM
Windows 7 automatically restarts explorer.
gamer says: Aug 7, 2008. 9:00 AM
Mmmmm.... Not on EVERY version of Windows.... Try to install Windows 3.1x on your computer and then try this.... Then tell me if it works.... It would be rather useless.... This just removes the desktop icons and the start menu. Only problem is that Windows 3.1x has no start menu or desktop icons... I don't even think it has a task manager...
SilentZoom (author) says: Aug 7, 2008. 5:10 PM
I'm pretty sure it works on every version of Windows since 95, and since most people use XP or Vista nowadays, I put in specific instructions for those.
Paten says: Jan 6, 2010. 4:00 PM
I like the old "CTRL - ALT - ARROW DOWN" command..  works a treat. Best to use it on work mates when they have left their terminals unlocked.
If you try it and get stuck you may need to make a slight adjustment to the command to resolve.
puffyfluff says: Aug 7, 2008. 6:53 AM
Hey! This is a direct copy of mine!
SilentZoom (author) says: Aug 7, 2008. 5:15 PM
I just looked at yours (I have seen it before, when I searched) and it's not the same thing. Mine is a lot more simplified, and doesn't require any specific commands with multiple modifiers that, if inputted incorrectly, might leave bad effects on the computer. This Instructable is designed to be easy, and executed without danger to the system.
puffyfluff says: Aug 7, 2008. 5:46 PM
Sorry. I forgot I made some changes. The original version was this, and then I added the batch file to it, and then I took the whole task manager away, because the batch was quicker and easier. And anyways, this is technically more risky than batch, because if you accidentally highlight the wrong process, then it is dangerous. If you mistype the taskkill command, it will return an error and do absolutely nothing.
kneecaps says: Sep 10, 2008. 6:52 PM
its not exactly dangerous if you end most processes. at worst it make your computer shut down. but it also gives you a one minute warning before it shuts off to save stuff or whatever.
puffyfluff says: Sep 10, 2008. 7:37 PM
Exactly. Especially since there is no other process similar to explorer.exe.
SilentZoom (author) says: Aug 7, 2008. 5:11 PM
Is it? I'm sorry. I searched multiple times for anything that was the same as this, and didn't find anything. I'll look at yours and if it is as you say, I'll remove it. O.K.?
runerocks15 says: Sep 8, 2008. 9:15 AM
in the task manager, click "file" and then "new task (run)". it will allow you to restore explorer.
Derin says: Aug 19, 2008. 10:47 AM
since explorer has been closed,you cant open the start menu
SilentZoom (author) says: Aug 19, 2008. 5:13 PM
Hahaha that's hilarious! Thank you for pointing the obvious out to me. I'll take it out.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
