Fun with teabag / bar trick
Hello there!
This is my first one so please...
Here i will show you how to make a simple rocket-like thing using teabag and matches.
Things you will neeed:
A teabag.
Fire source
Step 11)
1)
First take everything out of teabag and open it up like in this picture.
Remove the metal thing that connects both sides.
Make it like a tunnel or cylinder.
Don't brake anything.
55 comments
1-40 of 55next »
Apr 29, 2007. 12:03 PMmonZy says:
These are the special teabags, in europe only. Latviešiem ir viss pieejams :)
Mar 31, 2011. 3:03 PMbobdole5656 says:
um no i have som and i liv in montana
Dec 30, 2008. 8:58 PMjjjjake says:
thats y they didn't work so well with mine
Apr 19, 2010. 6:28 PMflamethrower1010 says:
 you waste about 3 times as much as you need to, you only need about 3 inches of the paper, if you cut it in 2 segments maby 3, you could repeat this trick 3 times insted of once.
Dec 12, 2009. 11:25 PMweaponscollector94 says:
um you misspelled "wrapped" and wrote "raped" just thought i should inform you!
Feb 26, 2010. 2:06 AMTeknix says:
No, he wrote right, the teabag is literary "raped" :D Get it? :D
Only latvians can make up such "trick" :D
Oct 30, 2008. 8:34 AMzeppozeppozep says:
Nice instructable although I think in future you should leave out the word "rape" when describing things. Aside from it being insensitive for no good reason it is also inaccurate since you really "gutted" the teabag unless you left out a step.
Oct 30, 2008. 12:19 PMzeppozeppozep says:
perfectly understandable.
Dec 27, 2006. 4:55 AMVisitor says:
The description about this trick is a bit incorrect. Temperature difference in the room makes no difference to whether the teabag flies or not. The common reason that prevents successful flight is ventilation. This trick is essentially a _very_ stripped down hot air balloon. 1. The fire heats the air above the teabag. 2. Hot air is lighter than cold air. 3. A column of hot air moving upwards develops above the teabag. 4. The air current provides lift. 5. As soon as the teabag is light enough (i.e. it has burnt down) the air current lifts it up. If there are other strong air currents in the room (from ventilation or air conditioning) the column will be disrupted and the teabag will not take off.
Oct 29, 2008. 2:47 PMLukes mate1 says:
how di u find that out?
Oct 30, 2008. 12:06 AMVisitor says:
I learned the physics part at school and I read the explanation somewhere in the Internet. I figured out that the explanation seemed credible and it fit within the laws of physics. So I decided that I could pass the information on as knowledge.
Oct 30, 2008. 8:17 AMLukes mate1 says:
oh cool thanks for telling me!
Aug 7, 2008. 1:56 PMDemoniclemon666 says:
lol that is a good story, and i like the advice!!!
Aug 27, 2008. 1:35 PMHiyadudez says:
which teabags are they?
Mar 31, 2008. 5:24 PMcyclonefan94 says:
He said teabag. That's worth a plus one right there.
Oct 7, 2007. 8:20 PMduck-lemon says:
i dont understand, more detailed instructions plz
Jan 31, 2008. 4:11 PMPyroMonger says:
watch the video and u will get it...it's very simple
Oct 14, 2007. 5:48 AMzorro3355 says:
hey! where did u get the music of that song? i only could find the track with eminem n music
Jun 30, 2007. 12:53 PMCorrosive Monkey says:
It's also good to ask the people around you to give you notes to put under the teabag before you light, and then watch their faces as they think you will burn their money. Of course you give it back to them afterwards.
May 30, 2007. 7:43 AMpyrotechnicallyprofessional says:
Any teabag works the same. Use any teabag you have. the reason it goes up is because once the teabag has been burnt it creates a residue which is lighter than air so it goes straight up! have fun !
Jun 23, 2007. 6:58 AMhlumbard says:
I don't think I'd say lighter than air. The ash just rises in the heat it just gave off by being on fire. The ash settles back down eventually so it can't be lighter than air. This is the same way ashes fly out of a camp fire too.
May 23, 2007. 4:57 PMGman the Gster the Ganator says:
lipton tea has the right size bags
Apr 4, 2007. 1:12 PMjwatriss says:
Yeesh... reminds me of a time in high school. Man, I really shouldn't admit this. In the bathroom stall, silly 15 year old boy loops the TP over the doorframe in the stall, and lights the bottom of it. Thermal currents, unforeseen to our hero, carry the whole burning wad of TP up and around the ceiling, threatening (or so I thought) to burn the building down, and there I am, literally, with my pants around my ankles. Would have crapped myself, had I not just finished, well, you know. Needless to say, it didn't start a fire or anything, but boy was it a terriying "oh, crap," moment. So, for the sake of being constructive here, let this be a lesson to all of you. If you're going to set fire to such things, remember to do so with your pants UP and your bowels clear, just in case you have to run and grab something to put out the ceiling.
Mar 28, 2007. 3:12 PMTomton says:
Is is the string inside or outside on that picture?
Mar 21, 2007. 2:51 PMeh says:
mine just burned down and stopped and i have the same teabag..?
Mar 21, 2007. 2:00 PMmusicisthekey says:
i like it but none of the teabags we have at my house are in the same format as the oen you showed there just paper squares with tea leaves inside
Mar 17, 2007. 5:01 AMmanmelvin says:
yo jarek_fx i liked your story this is my first time on here too im living in Ukraine right now Go eastern europe;p
Mar 17, 2007. 4:58 AMmanmelvin says:
sombody needs to put some card tricks or somthing on here im tired of knex guns! <(")>
Feb 25, 2007. 10:30 AMgobob29 says:
this is awsom
Feb 18, 2007. 6:55 PMstreet104 says:
thats pretty cool
Dec 30, 2006. 11:40 PMtheking says:
I tried this and set my house on fire!!! i hate you!
Dec 27, 2006. 4:42 AMjarek_fx says:
hello there, i'm mailing from poland. this is my first mail... in poland this trick is well known, but it is commonly showed with a small story - about russian rockets! here is the story: (YOU: take the teabag from the box, tell the story) ... One guy wanted to own a rocket to send a satelite to space. but US rocket was too expensive for him, so he asked guys from russia. they said - ok it will cost 1milion bucks. guy: it's too expencive is it possible to find a way to make it cheaper? russians: well, we can take out the stabilizers.. (YOU: take apart yellow paper label) guy: great, how much is for this option? russians: 500.000$ guy: well - it's still too much for me. can you find a cheaper way? russians: well, let's try to fly without all computer and electric wires! (YOU: pull out that twine which is connected to tea bag) guy: great! how much is for that now? russians: 250.000$ guy: no, no - it's still too much for me! do something! russians: well, last thing we can remove is FUEL! guy: GREAT! will this rocket fly? russians: sure. we did it before! guy: how much is then? russians: 100.000$ guy: great! do it! (YOU: open teabag and remove the tea leafs) russians: now, it is light and cheap! give us 100.000$ guy: here it is! (YOU: take small amounts from adults or sweets from kids) ... rest you already know. IMPORTANT: this rocket flies only if the temperature DIFFERENCE between table and upper part of your room is big enough! if it's similar this trick may not work! all the best! jarek_fx
Dec 25, 2006. 5:42 PMiZaP says:
i dont have the teabags like you do :(
Dec 2, 2006. 6:44 PMItalianStln323 says:
or, you could make the tea before opening the tea bag and then just empty the spent leaves and let the paper dry out . Then you don't have to waste any of that Earl Gray :P
Nov 28, 2006. 2:56 PMDieffsta says:
wait , do you take all the tea leaves out of the bag then light it? or leave them in...? please post answer....thanks!
Nov 28, 2006. 5:10 PMDieffsta says:
ok thanks...
Nov 27, 2006. 4:48 PMDieffsta says:
this looks really cool...its the best kind of instructable in my opinion, simple, yet extremely amusing
Nov 27, 2006. 12:13 AMldbrooks36 says:
Didnt work for me cuz-im a dum-ass!lolhaaha!
1-40 of 55next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:datelus
