3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pocket Sized Spring Loaded Dart
This is my first instructable, so any feedback (positive or negative) will be welcomed.
This is a spring loaded dart made of common items found in my local hardware store. My son and I saw something similar to this on a National Geographic special about the Chinese weapons. I don't remember what they actually called it, but from what I remember it was considered to be an assassin weapon. A low powered spring loaded dart that was typically dipped in poison. The weapon was easily concealed, and powerful enough to break the skin which in turn administered the poison. My version will shoot about 35 feet. I imagine that if I put a tip on the dart it would travel further due to aerodynamics.
Step 1Material and Tools
Material and Tools
Everything I used to build this was found at my local hardware store.
Parts Lists:
1 - Shut off valve with chrome sleeve
1 - Short length of 1/2" copper tubing (2-3/4" long)
1 - 1/2" copper cap
1 - Strike plate
1 - Washer #10 I think
2 - Set screws 6-32 thread 1/8" long
1 - Length of aluminum solid tube 1/4" diameter
2 - Springs (#11 at my hardware store)
2 - Bronze bushing (5/8"O.D. 1/2" I.D.)
2 - Bronze bushing (1/2"O.D. 3/8" I.D.) Not pictured sorry
2 - Bronze bushing (3/8"O.D. 1/4" I.D.)
1 - tube of Locktite
Tools:
Solder iron
Torch
Dremel
Hammer
pipe cutter
Various files
Drill
Allen wrench
31 comments
Jan 24, 2011. 2:49 AMskimmo says:
does the screw hit the spring?
Jun 25, 2009. 3:12 AMlemminggenocide says:
i cannot believe that nobody else has commented on this, it is such a well designed and thought out piece, it is somewhat reminiscent of some of the more dangerous zip guns, which require bullets to fire. I am planning to make an instructable on a small steel crossbow soon, if I do, i will definitely include a link to this i'ble, because I think that it is highly unjustified that this has received less views than other really basic, boring weapons, like the ten thousand "skewer launching" items that even the average ten year old could make without any instructions. 5/5 please make more instructables, you obviously have a very comprehensive understanding of the technical side of things (and some awesome dremel skills) keep up the good work LG oh also, you are my first subscription
Nov 20, 2010. 3:20 PMSlicerr2 says:
look at page 76 on offbeat thats one place though i stummbled across it on a search to
Nov 20, 2010. 3:37 PMSlicerr2 says:
or page 98
Jun 26, 2009. 12:31 AMlemminggenocide says:
i think it came up when i searched "metal dart"
Nov 20, 2010. 9:59 AMSlicerr2 says:
this is great right now i am working on one of these out of pens and house hold materials
Nov 20, 2010. 1:31 PMSlicerr2 says:
so in the end i could not get any pens to fit over top of each other and fit my spring but i have started making one of scrap steel from behind our shop and so far i have the spring and the tubing for the spring ready i found that i did not need a end cap i just cut a cross into the pipe and bent the sides down it worked really well
Aug 24, 2010. 9:08 AMtdwp1122 says:
Thanks so much for the instructable. I finally was able to build mine. I changed it so instead of using a steel pipe i used another copper one. it gave it more of an "old" feeling to it. Great Instructions!
Feb 5, 2010. 6:32 PMtdwp1122 says:
(removed by author or community request)
Dec 10, 2009. 1:33 PMprabhjot999 says:
how much money did this cost
Oct 17, 2009. 5:37 PMtdwp1122 says:
 where do you get the shut off valve? I have looked everywhere for it. If you could help me out that would be great.
Oct 9, 2009. 4:28 PMweaponscollector94 says:
so...this is sorta like a ballistic knife! this is awesome i am going totally make one! ya i have built several ballistic knives so i guess it is the same concept!
Aug 12, 2009. 8:44 PMtaterkiller says:
how much does cost to make
Aug 23, 2009. 10:35 AMpyroninja21 says:
you could increas its aro dynamics by super glueing a rubber tip in the end its an ok idea hope it helps
Jul 31, 2009. 4:01 PMhistory323 says:
WOW! I CANNOT believe this has so little comments! It is so cool! I am going to make one right now!!!!!
Jul 2, 2009. 3:38 PMmoo of the cow says:
could you make this with a camping spring????
Jul 1, 2009. 12:42 AMmoo of the cow says:
this is pretty awsom im gonna make the its probly better then my crossbow with is like 2m wide (bow) and is very annoying to carry
Jun 27, 2009. 6:05 PMsjonahm16 says:
This is great, and the weapon you're talking about is called the "Chinese sleeve arrow dart".
Jul 2, 2009. 10:21 AMGenises says:
i fully agree with lemming genocide this deserves more views!!!!
Jul 2, 2009. 7:05 AMzoogigle says:
so how far does this thing shoot?
Jun 25, 2009. 12:19 AMlemminggenocide says:
cool!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:ClayChip
