loading
Step 11: Calibrating the controllers for the first time
Next, you'll need to calibrate your controller for use.   Like the last step, this step only needs to be done once.
Launch the program, "PPJoyCOM" and set the Com Port to match the one you found earlier with Propeller Tool.
Calibrate your controllers:
Leave PPJoyCOM running, click on Windows START --> Control Panel --> Game Controllers.
  • Click on Properties
  • Click on the Settings tab
  • Click on Calibrate
Use the thumbstick on the N64 controller for calibration.  All of the other controls will fall out fine.
You'll be able to see the controller and buttons work in the test window.
Congratulations!   Your Funtendo is ready for use!   Simply Launch PPJoyCOM when you want to play and take off!
<p>Or use the consumer alternitive. </p><p>http://www.bliss-box.net/Bliss-Box/KS.php</p>
I'm planning to addabted something like this for a project I plan to break ground on here soon, but the issue is this [Funtendo] would be used on a linux platform. So two questions: <br>-Will it work with linux? <br>-And can you set it up with other controllers? Sega, for example.
how is the analog stick response on this? does it work properly? <br> <br>is it possible to modify the code to register each controller as a seperate controller? if so, how could i modify the code to make it all n64 controllers?
Is it possible to have all three controllers of the same type, i.e. 3 n64 controllers.... and have them each dedicated as a different player... player 1 controller, player 2 controller, and player 3 controller? is there enough terminals on the board to add a third controller? i guess what I'm asking is would it be possible to use this device as a 4 player n64 system?
The wife and I use two of the controllers to play games against each other.<br>Because both controllers are active all the time, we try not (or maybe we do) to touch the controller to mess each other up. <br><br>I can't see why this project couldn't be adopted to multiple controller use. Adding some logic code to the funtendo.spin could even make it so that the active controller could pass the controls to the next unit.<br><br>OBC
A discussion regarding adding a SNES controller has been started at: http://www.gadgetgangster.com/forums/viewtopic.php?f=3&amp;t=21<br><br>OBC
Hey GG, just a quick note - in case you don't want to destroy your wii classic controller cable (they are expensive) you can get a Nunchuck adapter here: http://www.sparkfun.com/products/9281. That might work for your needs since it's the same kind of connector as the nunchuck. Obviously the labels on the adapter will be wrong, but that's something you can work around. At least you save your precious controller or extension cable. They are expensive!
Here's an Ebay link to the one I used.. <br>http://www.ebay.com/itm/Extension-Cable-Cord-Nintendo-Wii-Remote-Nunchuk-/260601944338?pt=Video_Games_Accessories&amp;hash=item3cad161912#ht_3024wt_860<br><br>$1.88 with free shipping out of HK. Hard to go wrong there. :)<br>
Gadget Gangster, I love you guys (the Christmas present two years ago was the best!), but this seems almost a bit of an advertisement. The fact that you are using two pieces of gear manufactured by you is a bit of a red flag. Kind of like letting the foxes design the hen house. You might do your readers a favor and show them how to do this with a breadboard in the event they can't afford the very affordable modules you provide. Otherwise an outstanding tut!
@soshimo:<br><br>Thanks for the kind words! I used the Propeller Platform w/Terminal Module in this project to make it as easy as I could for someone to build their own. I could have used a PCB, but the combination of the ready-to-go Propeller Platform and the screw terminals on the plug-in board pretty much guaranty success for other builders. That being said, not providing a schematic was a bit of an oversight on my part, and I'll make sure that all future projects have plenty of additional documentation for those who have Propeller DIPs, breadboards/PCB's.
Excellent suggestion regarding the documentation! That's a great compromise for those DIY'ers out there (myself included). My confidence and loyalty is restored. You guys really are a class outfit!
How much did this cost you?
The controllers I already had. (I'm a game system collector, and retro-head)<br>I also had the USB hub and 2gig flash drive in a box of parts, so my costs for this project were three extension cables from Ebay (around $5.00 a pop), the project box from Radio Shack ($7.00) and the two Gadget Gangster boards ($55.00).<br>I love to do projects that people can follow behind and replicate, so cost vs value is a figure that I always look at. The value of doing it yourself weighs in heavy, the onboard storage isn't supported by a simple adapter cable, and the Propeller will allow you to modify the code, so all-in-all I'm pretty pleased with the project.
DEAR SANTA!
Retro gaming, awesome!
About This Instructable
16,009views
120favorites
License:
More by Gadget Gangster:Hack Your Car Talking Resistor Calculator Bananaphone: A Touch Capacitance Synth
Add instructable to:
