The furby's in-built sensors and actuators:
light sensor,
IR sensor,
IR transmitter,
tongue touch sensor,
belly touch sensor,
microphone,
speaker.
The furby's main (and only) motor was dead, so I added other motors.
Remove these ads by
Signing UpStep 1Skin the bastard
Once it's off you'll see connectors on the left and right of the furbies body, these are the wires connected to all the sensors. You should even see written next to some of the wire connections 'S1' 'S2' (sensor 1 and sensor 2, etc). Figure out which wires go where.
Above the furby's eyes:
-In the center is a light sensor (changes resistance in response to light)
-On one side of the light sensor is an IR emitter (like on your TV remote)
-On the other side is an IR receiver (like on your TV)
On the furby's sides:
Left:
-wires from the belly touch sensor
-wires from the speaker
Right:
-wires from the tongue touch sensor
-wires from the microphone
solder longer wires onto any sensor wires you want to connect to your PIC, label them.
Bare feet are another thing altogether though.
I am just getting back into electronics for gcse =/
Good luck if your still active =]
lol
The furby project isn't very easy if you haven't used microcomputers before. There are many different types of microcomputers, I used the PIC. PICs are hard to learn how to use in a short amount of time. The best microcomputer to start learning with is the basic stamp (that's the one I learned to use first). The problem with the basic stamp is that it's harder to do analog to digital conversions (necssary to read from the furby's light sensor), but other than that, the basic stamp would be fine for the furby project. HEre's where you could get the basic stamp from:
http://www.parallax.com/detail.asp?product_id=BS1-IC
To program the basic stamp you can either build your own circuit to interface the basic stamp with your PC or you can buy a 'module' that makes programming the stamp easy: http://www.parallax.com/detail.asp?product_id=27111
if you want to try using a PIC instead of a basic stamp here's where to get it from: go to www.digikey.com and search for PIC16F877-04/P-ND
To program the PIC you'll need a PIC programmer such as this one: http://cgi.ebay.com/USB-PIC-Debugger-Programmer-Microchip-icd2-icd-2-mplab_W0QQitemZ300096357766QQcategoryZ4661QQrdZ1QQcmdZViewItem
here's where to get the motor controller (H-bridge) from: go to www.digikey.com and search for 497-1389-5-ND
For the motors, you can either use lego motors if you have them (that's what I used) or look for good motors here:
www.allelectronics.com
(for instance: http://www.allelectronics.com/cgi-bin/item/DCM-261/400/6-20_VDC_MOTOR,_MABUCHI_FK-280_.html)
make sure that the voltages that the motors need can be supplied by whatever batteries you use.
to make the necessary circuits you'll need a
1) breadboard
http://www.action-electronics.com/breadbrd.htm?zoom_highlight=breadboard
OR
http://www.allelectronics.com/cgi-bin/item/PB-1680/search/BREADBOARD,_1680_CONTACTS_.html
2) breadboard hookup wire
http://www.allelectronics.com/cgi-bin/item/18RD-100/search/18_GA._RED_HOOK-UP_WIRE,_STR._100"#39;_.html
3) wire wrap sockets
http://www.action-electronics.com/icsockets.htm#Hrww
4) wire wrap wire
http://www.action-electronics.com/pdww.htm#Wire
5) and a wire wrap tool
http://www.action-electronics.com/pdww.htm#Wrap
6) wire wrap perf board
http://www.allelectronics.com/cgi-bin/item/PC-4/search/SOLDERABLE_PERF_BOARD_.html
7) a multimeter
http://www.allelectronics.com/cgi-bin/item/DVM-810/search/ECONOMY_DIGITAL_MULTIMETER_.html
for more advanced electronics you should have:
8) a soldering iron (may not need it for beginner circuits but it will be useful, especially if you want to make the bump sensor like I did)
http://www.allelectronics.com/cgi-bin/item/IR-30/search/30_WATT_SOLDERING_IRON_.html
9) soldering iron stand
http://www.allelectronics.com/cgi-bin/item/50B-205/search/SOLDERING_STAND_.html
10) solder
http://www.allelectronics.com/cgi-bin/item/SOL-564/search/1_2_LB_ROLL,60_40_SOLDER,_.032"#34;_DIA_.html
11) perf board
http://www.allelectronics.com/cgi-bin/item/ECS-1/search/SOLDERABLE_PERF_BOARD,_1_HOLE_PAD_.html
12) DIP sockets
http://www.allelectronics.com/cgi-bin/item/ICS-24N/search/24_PIN,_NARROW_DIP_IC_SOCKET_.html
http://www.allelectronics.com/cgi-bin/item/ICS-18/search/18_PIN_IC_SOCKET_.html
