3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Furniture grade cocktail arcade cabinet
Step 4Preparing the pieces
For the base, you can probably get them to cut the 24 x 48 inch piece of plywood in half with their panel saw at the store before you check out and then trim it to a more exact dimension when you get home. I used my cordless circular saw and trimmed off the corners with a jigsaw.
To make the front and back parts you will need to glue up 2 12 inch wide pieces. I didn't have any long pipe clamps, so I pressed them together by hand, stapled across the joint, and then put a heavy weight on top of the drying piece. If you've got a biscuit joiner, use it! This worked out pretty well since later on they both get a brace somewhere across the grain and the joint. You might notice that there's not quite enough wood to make up boards of the exact length after taking the saw's kerf into account. Don't worry - the front gets 10 degrees trimmed off later and both pieces can be up to a 1/4 inch too short before anyone will notice.
From the 10 inch wide board you should cross cut off enough to make the 2 front side pieces and then you can rip the remainder down to make the back sides and top sides. The rest of the pieces can be cross cut to length and then ripped or planed to the correct width later. Some pieces need very specific notches and radii to be cut so that the pieces will fit together. Look to the provided measured drawings for proper dimensions.
--- EDIT ---
I've added a second layout image so you can see how to get the needed parts from two 2x4' 3/4" thick MDF sheets (medium density fiber). This will make the unit very heavy, but is a cheaper and simpler way of building an arcade cabinet. If I was going to mass produce them, this is how I'd go :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
28
Author:mydian_nightshade
I'm a product designer who works at an e-commerce / gadget & toy company out in Fairfax. I make furniture, decorative boxes, and other fun stuff in my free time.
