Furniture Risers - Help Cleaning Droids Catch More Dust Bunnies Under the Sofa
11,871
43
14
Posted
Introduction: Furniture Risers - Help Cleaning Droids Catch More Dust Bunnies Under the Sofa
We got a cleaning droid. A Neato to be precise - it's a lot like a Roomba, but it's a Neato. It's a cleaning robot, not quite R2D2, but it's getting there. The kind of thing that likes to wake up and make a lot of noise while bumping into things when you want peace and quiet. Aside from getting stuck on shoelaces and moving the cat bowls from one room to another, this thing manages to fill it's basket with dirt on a regular basis. But it has it's limitations... furniture induced limitations. As hard as it tries and as persistent as it is, it just can't fit under the coffee table or the sofa. Until now!
There was a need.
I created a solution.
Custom foot risers to lift the furniture.
I did two sets - one for the coffee table, and one for the sofa. This isn't fine furniture we are talking about, but it comfortable and I think the cleanliness will out weigh the incongruence in design.
Supplies Needed:
Wood - as thick as needed for proper clearance.
Stain - to match existing finish
Screws - to affix riser to furniture
Felt pads - so you don't mar the floor
Tools used:
Pencil
Straight edge
Chop Saw
Band Saw
Drill press and drills
Belt Sander
Paint Brush
Screw Driver
Step 1: Measure Clearance for Cleaning Droid
How much taller does your furniture have to be for the little cleaners to get underneath?
Select your wood accordingly. I used a nice piece of Oak 1" thick for the table risers and a Pine 2"x4" for the sofa.
Step 2: Measure and Cut Wood Blocks
Flip your short sofa or table over.
Sweep out the dust bunnies and cat toys that were hiding under there.
I was able to unscrew the sofa foot to bring it to the shop, but had to do the table leg measurement on location.
I traced the bottom of the existing leg onto the wood to get the widest point measurements.  This will be the mating surface at the top of the new riser.
Cut the four blocks to size on the chop saw.
My furniture has an angle cut into two sides of the legs, so I used a straight edge to follow that edge, marked it and cut on the band saw. I matched the angle of the second side and cut it as well.
Repeat process until you have enough.
Step 3: Drill Holes for Mounting Risers
Screwing the riser to the furniture will be very secure. Drilling a pilot hole for the screw with a counter sink will let the screw seat well and prevent your wood from splitting.
I drilled a larger hole than the size of the screw head, then drilled a smaller hole about the size of the screw shaft.
Step 4: Finish Sand Your Risers
Using the belt sander, I cleaned up the surfaces and edges.
A smooth finish will make the stain look better.
Step 5: Stain the Risers
Use your favorite stain - or better yet, use one that matches your existing furniture.
Mine was a mahogany color and it had a polyurethane coating built in.
Glop it on, smooth it out, and watch it dry. Seriously - sit down and watch it dry. Contemplate how this simple project will cut down on dust in your home. How the cats will have an easier time collecting lost toys and how far you will have to reach if the droid gets stuck under the sofa. If you are done with your zen moment, go do something else - this stuff takes a while to dry.
Step 6: Drill Them and Screw Them On
Flip your sofa and table upside down and remove any old felt pads or slider buttons.
Line up the risers and using a drill bit a bit thinner than your screw, drill a pilot hole into the existing table leg or sofa foot.
You can add wood glue at this point if you like. I didn't, but you could for a more permanent bond.
Screw them in snugly.
Step 7: Cut Felt Pads, Stick Them on and Be Protected
I got large pads of felt slider material so I could cut to fit.
Do that. Cut four pads to fit on the bottom of the stack. Peel off the backing and stick them on.
Step 8: Flip Your Furniture Back Over and Test Out Your Cleaning Droid
Put everything back where it goes.
Enjoy your new view... it's a little higher than before!
Test out your Neato or Roomba and see if they can get in there and rustle up some dust bunnies!
I used the tools at the Tech Shop in San Carlos California to create this project.
http://www.techshop.ws/
It was nice to have a full wood shop at my disposal, so I used it. You can do this with hand tools if you like, but it's faster this way.
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Minecraft Challenge 2018
14 Comments
I like the way you think, I always lay on the floor an extendable camera tripod in front on one of my TV stands that my irobot tends to get stuck under.When I can get some strong guys to come over here, take off the TV and turn over the large stand, I will definitely do this. I will have the lifters ready, then I will paint the entire thing a pale gray, thanks.I have several sets of good high casters, never used, I may use them. Thanks for the inspiration, things I should have thought of, but everyday life worries get in the way.
Is it just an sweeper or does it suck too?
sweeps and sucks... like any good cleaning droid ought to.
Did your parents know you were using their tools?
sorry, they are dead.
These are the droids you're looking for... (or perhaps: "these are what the droids are looking for")
Genius! And the risers look really nice - I like the new two-tone look to the legs.
One variation I did for short furniture (sofa with matching chairs) was to replace the short legs with bed mattress wheels. Also makes it easy to move furniture when company is coming.
