iImage Information
How to make a fused matchstick rocket. Safer, and far more dramatic than the conventional kind! Still, exercise caution with these things - and remember, I'm not responsible if you blow your hand off with one of these things.
You'll need:
- Matches
- Scissors
- A pin
- Access to a stove
- String
- A paper clip
- Kitchen foil
Step 1Make a fuse
iImage Information
The first step is making a fuse. This is not difficult, but the smell is terrible. Cut the heads off around 50 matches. Now, put a small amount of water into a pan, and get it simmering. Drop the match heads into the pan, and swish them around. After around 5 minutes, drop the string in as well. Stir this around for another 10 minutes.
That's it! With care, take out the string and leave it to dry.
As you may notice in the comments, it's also possible to soak the string in nail polish or rubbing alcohol (or some other flammable liquid).
-Y
- Power the wieght: The main concern this cool little gadget only produces so much thrust so it can only lift so much wieght. Adding more matches adds more launch wieght because only so many matchheads are burning at one time so only so much thrust is being produced. A match stick rocket can lift itself, and another matchhead pretty easy so stacking a matchhead (cut the stick part off) ontop of the other match, both of them tightley wrapped inside the foil, gives the most reliable results.
- The Exhaust Channel: This is the key stone to this entire project, if the channel is too large then the exhaust gas won't create enough thrust. If the channel is too narrow then the foil won't be able to contain the preassure and the gas will escape from somewhere else. If residue from the spent fuel plugs up the exhaust channel then the remaining fuel will be wasted. If the channel does not reach all of the matchheads (while maintaining a narrow enough path) then those matchheads will not contribute to the lift.
as a rocket, this flys?
i seen all and though about what could possibly happen
all i can figure is that it makes a lot of smoke, and can't fly
if possible give me an answer as quick
The rocket does actually fly! It works like any other rocket engine - forcing hot gases out through a nozzle very quickly.
As the match burns, air around it is heated, and some gases are produced as a result of combustion. These gases can only exit through a small hole - resulting in a "bottleneck" effect. Thus, thrust is produced! Of course, this amounts to only a very small lifting force, and the rocket doesn't go far. Plus, they aren't too reliable - it may take a couple tries to get it to work. But, it WILL fly!
- Gehn
xD
thanks
