Step 7Make the Hood
Lay one side of the hood outside up on the cardboard surface.
Starting at the neckline, lay the vertical band along the back edge and fuse using the guide. As you approach the curve hold the band perpendicular to the surface and carefully iron around the edge curving the band to match the edge.
Place the second hood side outside up on the surface and repeat.
Open the hood a and place the vertical band flat on the work surface with the seams pointing up. folde the seams pointing to the band side and carefully fuse. This gives the hood a good shape and hides the edges that can be irritating on your neck and face.
Add Comment
