Step 8Attach the hood
You may need to tweak the collar line on the jacket and make sure that it is a nice matching curve that flows from the gently curve at the back through the sleeve to the front. When you put the jacket on, the neck hole should be a nice round hole with a v-neck front.
Open the jacket and place it inside down with the collar stretched as straight as possible.
Place the hood inside up atop the jacket and align the edges. Since this is a conceve curve it can be a bit more difficult. To make it easier I fused a small section at the back of the neck and then a small tab every inch and half to attach the hood and be sure it was all aligned properly. After the hood was attached, I then ran the continuous seam along the entire edge.
Add Comment
