Fusion Coil (Halo 2 Style Game Case)
Introduction: Fusion Coil (Halo 2 Style Game Case)
This is designed as an alternative to modern £50 price range limited edition games (In particular the Halo Reach one). I felt that customers would be better encouraged to buy it if it were more heavily themed on the game itself, so my intention was to create a box to hold the game and keyring for Halo Reach designed around the fusion coil.
Update: As  per request, I've uploaded the files I made for this model. You may have to print out additional grey strips, since the paper graphics won't fully cover the outside of the model. DROPBOX LINK!
Step 1: 2D Design
This step should have been included from the beginning, but oh well, better late than never! Some may be more appropriately placed on their respective steps, but I wanted to put all the 2D design screenshots here (And by the way, I would not have been using 1024 x 768 monitors if there had been any other way!). All nets are of my own design, and the pictures are as follows:
1. Coloured orthographic diagrams. The transparent pair on the right show the intended placement of the plastic tube, and the middle one shows the removable tube that would hold the game and keyring (Like the actual Reach case), but I scrapped the idea due to work load.
2. Two of the sides and the top. I have a modified version without the hinged lid for the bottom, which includes the other 2 sides. The handle was just to test the idea out, and I made a second version out of plastic (Which actually springs back flat when you let go!).
3. The net for the "Inner tube" (See next step). It also includes a square bevel to line the top edge of the inner tube, and a smaller lid shaped piece. This gives it a heavier feel and a better quality close.
4. Basic key ring holder, taking into account the width of the inner tube and the thickness of the game.
5. Texture filled version of the top net. I did not modify the net, hence the later on white gaps.
6/7. The top and sides with logos added. Again, the bottom was left without the hinged lid or any logos.
Step 2: Inner Tube
I missed a few photo opportunities, but here is the nearest to the beginning. I had basically started with an open topped cuboid  about 108mm x 108mm x 270mm (150mm diagonally, allowing a game case to fit in diagonally) and attached clear plastic windows that protrudes about 1.5cm
These windows were originally meant to be a complete cylinder, but i messed up on the diameter (Somehow ended up 140mm) of the hole later on, and had to adjust the windows accordingly.
I then glued a 9v battery connector to the bottom, adding holes for the connectors to pass through.
Step 3: Lid / Underneath / Sides
At this point I'll mention that i was lucky enough to have access to a laser cutter and A3 printer. It is possible to make this without, but extremely frustrating should you make a mistake. "Measure twice... cut once!"
The lid was a modified version of the underneath, with a 1mm rim cut out, and a bevelled internal rim to prevent it folding in on itself. I added a score line on the underneath of the lid to allow it to open properly.
The photo shows how the sides are taped to the underneath. Sorry i took no pictures beforehand, but the printed shapes in the next step give the idea of it!
Step 4: Assembly
The collection of all the pieces so far, including 8 red LEDs, a small plastic handle, electrical wire (17p per metre at Wilko's!), and tracing paper as backing for the window panels.
Step 5: LEDs
I soldered the 8 LEDs in parallel (Obviously!) in a daisy chain, like chrismas tree lights are. I then used a small glue gun to attach them about 5cm from the tops and bottoms of each side, allowing the chain to snake up and down while rotating around the tube.
Step 6: Colouring / Testing
I used a yellow felt yip pen to colour the tracing paper before gluing them to the printed pieces. Be careful not to use grease proof paper, because this repels most types of ink (EVEN SHARPIES!)
The results look rather promising, although maybe yellow/orange LEDs would have been better!
Step 7: Keyring
I made a basic keyring using low melting point alloy and a laser cut MDF mould. I then made a very basic display stand to hold this that would fit inside the case (Allowing enough room for the game case).
The combined keyring and stand took about 4 hours total to make.
Step 8: Printed Graphics
These photos show the relatively easy task of adhering the inkjet printed graphics to the case. Unfortunately, as an expected problem, the vertices take up about 2mm of the paper, so the curved paper meetig the plastic window ends up about 4mm short. I plan to fix this by gluing strips of the metal texture to the white gaps to cover them up/
In the dark, the effect is really great!
Update: I fixed the white patches using different length rectangles and curves of the same tecture (Albeit slightly darker). The effect looks like it has been seam welded, which is actually pretty good, and at least much better than plain white. Enjoy, and don't forget to rate!
Step 9: Game Cover
I designed completely from scratch, even taking the screenshots for the Spartan and Elite, a new front cover for Halo Reach.
It's not graphically perfect as a game cover, as it is too busy and does not represent the style of the game, but it is abstract and you could argue that the contrast between black and white represents the clash of good and evil, and the red signifying bloodshed, and the blurring between colours begs the question: Which side is actually wrong, for in the midst of war are we not all bretheren?
Just kidding, I still only made it as a pretty pattern!
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    Halo 2 is the best halo made!!!!
    um can you give a download link for the parts? XD
    Eeeeyup, just uploaded them. Check the intro for the download link!
    what is the use of fusion coils in the actual game? the only thing i know they are for is explosions.
    In the story they are sources of power, a bit like portable petrol generators, except they generate electricity through nuclear fusion (On Halo 3 you can see the high voltage warnings).
    In multiplayer however, they serve a small purpose as hazards around the map to even up the advntages of vantage points, most notable the (Plasma Batteries) on the top of the spiral ramp on Guardian... a well placed granade would detonate these and even kill an overshielded player.
    I'd really love to know how you made it :/ Maybe it's more fitting to be a slideshow, as there aren't really any instructions in it,or maybe I'm just not reading them carefully enough. I understood up to step 2, where there were no source to the templates you used. If you would post the templates if there are any (you used an A3 printer, are those special or are they like regular printers where you cut, fold, glue? then it would be better. I'm not saying it's bad, it actually really looks authentic. 3.5 out of 5, better than anything I could make.
    Okay... here's the necessary update on the making part. Hope it helps... looking at it now it seems to explain a hell-of-a-lot more!
    Sorry... you're right. Most of the work I did is in the form of 2D design files. I had the fusion coil picture from Halo 2 and worked out how I could produce the net in as few pieces as possible (Trigonometry nightmare with working out the angles and sizes that would let it fi together correctly), which I then used a laser cutter to "print" (ie. cut) the designs to.
    I used the same net but filled in with a grey texture and some graphics I imported to print on a standard A3 inkjet printer, cut out, then glue to the card.
    I'll upload some of the 2d design screenshots later so you can see what I mean.
