Introduction: Fuzz Pedal
Picture of Fuzz Pedal
Once you have your guitar and learned how to play in time with a metronome, the only thing left to do is rock out. However, as you might have noticed, no matter how hard you rock, it just does not sound right. That is because you are missing something. As many guitarists will tell you, the secret to rocking out is actually fuzz. Before you can do any serious rocking out, you are going to need to build a fuzz pedal. Fortunately, making your own fuzz pedal is a lot easier than it may sound.
Step 1: Go Get Stuff
Picture of Go Get Stuff
You will need:
- (x2) 2N3904 NPN Small Signal Transistor (Model: 2N3904 | Catalog #: 276-2016)
- (x2) 100K Ohm 1/4-Watt Carbon Film Resistor (Model: 271-1347 | Catalog #: 271-1347)
- (x2) 10K Ohm 1/4-Watt Carbon Film Resistor (Model: 271-1335 | Catalog #: 271-1335)
- 22 uF Electrolytic Capacitor (Model: 272-1026 | Catalog #: 272-1026)
- 0.1µF 50V Hi-Q Ceramic Disc Capacitor (Model: 272-135 | Catalog #: 272-135)
- 0.01µF 50V 20% Hi-Q Ceramic Disc Capacitor (Model: 272-131 | Catalog #: 272-131)
- 10K-Ohm Horizontal-Style Trimmer (Model: 271-282 | Catalog #: 271-282)
- 5K-Ohm Linear Taper Potentiometers (Model: 271-1714 | Catalog #: 271-1714)
- 100K-Ohm Audio-Taper Potentiometer (Model: 271-1722 | Catalog #: 271-1722)
- Multipurpose PC Board with 417 Holes (Model: 276-150 | Catalog #: 276-150)
- SPST Flatted Metal Lever Toggle Switch (Model: 275-634 | Catalog #: 275-634)
- 1/4" Mono Panel-Mount Audio Jack (Model: 274-255 | Catalog #: 274-255)
- Hexagonal Control Knob (Model: 274-407 | Catalog #: 274-407)
- Fully Insulated 9V Battery Snap Connectors (Model: 270-325 | Catalog #: 270-325)
- Enercell® Alkaline 9 Volt Battery (Model: 23-853 | Catalog #: 23-853)
- DPDT specialty stomp switch
- Sturdy metal project box
Step 2: Mark
Picture of Mark
On the top surface of your project box, measure in one inch from one of the shorter edges. Next, make two marks that are 1/3 and 2/3 of the way between the edges of the shorter distance. These will be for the potentiometers
Measure in one inch from the opposite side of the front of the case. Make another mark that is 1/2 way between the two edges. This hole is for the stomp switch.
On the side of the case make two marks for audio jacks where you would like, so long as they won't interfere with any of the other parts that will be installed.
Following the same logic as the audio jack marks, make one last mark for a toggle power switch.
Step 3: Drill
Picture of Drill
Drill the two holes for the potentiometers with a 9/32" drill bit.
Drill a 1/8" pilot hole for the stomp switch and then widen it to 1/2".
Drill two 3/8" holes for the audio jack.
Finally, drill a 1/4" hole for the power switch.
Step 4: Solder
Picture of Solder
Build the circuit as specified in the schematic.
For now, don't worry about attaching the potentiometers, stomp switch, audio jack or power switch to the circuit. These will be wired in later, after they have been installed in the case.
Step 5: Wires
Picture of Wires
Attach a black wire to the center pin of the 5K potentiometer and a red wire to the pin on the right.
Attach a black wire to the left pin on the 100K potentiometer and red wires to the two other pins.
Step 6: Audio Wires
Picture of Audio Wires
Attach a black wire to the ground lug on each of the audio jacks. Attach red wires to the signal lugs on each of the jacks.
Step 7: Install
Picture of Install
Install the audio jacks and the DPDT stomp switch into the metal case.
Step 8: Wire
Picture of Wire
Solder each of the red audio wires to one of the center lugs on the DPDT switch.
While you're at it, solder together one set of outer pins.
Step 9: Attach
Picture of Attach
Attach the potentiometers to the circuit board as specified in the schematic. Keep in mind that one of the potentiometer wires will be later attached to the DPDT switch.
Step 10: Cut Brackets
Picture of Cut Brackets
Cut out two brackets using the template file attached to this step. They both should be cut out of non-conductive material.
I cut out the larger base bracket out of a thin cork mat and the smaller potentiometer bracket out of 1/8" rubber.
Step 11: Put in the Pots
Picture of Put in the Pots
Line up the rubber bracket with the holes in the case and install the potentiometers into the case.
Step 12: More Wiring
Picture of More Wiring
Wire the remaining potentiometer wire in line with the audio-out jack's wire on the DPDT switch.
Connect a wire from the remaining DPDT terminal lug to the audio-in point on the circuit board.
Step 13: Power Switch
Picture of Power Switch
Connect the red wire from the 9V battery connector to the center terminal of the power switch. Connect another red wire to either of the switch's outer terminals.
Step 14: Switch
Picture of Switch
Install the power switch into the case.
Wire the black wire from the 9V clip to ground on the circuit board and the free red wire from the switch to +9V on the circuit board.
Step 15: Power
Picture of Power
Plug in the 9V battery.
Step 16: Case Closed
Picture of Case Closed
Install the large insulator panel between the circuit board and the bottom plate of the casing.
Screw the case shut.
Step 17: Knobs
Picture of Knobs
Attach your knobs onto the potentiometers.
Step 18: Plug and Play
Picture of Plug and Play
Plug your guitar to audio-in and your amp to audio-out. Then, rock out.
jeff124 (author)2016-04-06
Just built one, got it working after adding a jumper between the unused pin and the center pin on the vol. control (5k audio). sounds great, not even in a box and very little hum. Thank you!
JovilasB1 (author)jeff1242017-12-06
Wich pin is unused? And it would be really usefull if you would upload a block diagram
dexter012354 made it! (author)jeff1242016-04-28
Hi Bro..can i have a favor??? can i have a block diagram like this one???
please bro, i need it tomorrow
AngelKnight113 (author)2017-05-23
How do you add A Tone Pot... ? Coz Your diy Od pedal has one
GeraldinoT (author)2017-05-09
do this have a tone knob??
randofo (author)GeraldinoT2017-05-10
No. Just volume and gain.
GeraldinoT (author)randofo2017-05-10
whats the use of 5k pot??
JoeyG40 made it! (author)2017-04-05
I made it. However, there is a troubleshooting. I get no sound at all. I did everything in this instruction. All I got is hummimg sound through the amp when I press the stomp switch. I need help. I'm making this for my project.
randofo (author)JoeyG402017-05-10
I have no idea. Perhaps start by checking to make sure your wiring is correct. Next make sure your solder connections aren't crossing. Also, make sure no parts are heating up.
Did you build it on a breadboard first? Did that work?
stanford.todd (author)2015-01-15
This is the best I can do to understand what's what but even then I don't exactly understand how this applies to the circuit board etc.
Can i have the diagram of the connection in the dpdt switch to the circuit???
josuchav (author)stanford.todd2015-04-14
The three lines you marked with a question mark are the ground or negative pole on the battery.
What you marked as battery leads is actually the positive port of the battery.
Colorblindpoet (author)2015-09-01
Cool thank you very much.
Martinblaze (author)2015-11-22
Ok I built it and am not getting any sound other than fuzz, no guitar. I used wires from a RCA jack, I figured it wouldn't matter since it is just signal strength. It's my first time building anything electronic but I understand the concept well enough, well maybe not since it didn't work. no change in sound when I turn the volume or tone either. the schematic didn't show which side of the transistor was the collector so I guessed it was the side with the battery.?
dexter012354 (author)Martinblaze2016-04-28
jeff124 (author)Martinblaze2016-04-06
had the same problem, the volume control need a jumper between unused terminal and center terminal. not shown in instructions but shown in schematic
igcasenza_b (author)2016-04-27
what is the configuration of the dpdt stomp. Can i replace it by sliding dpdt ?
trazman001 (author)2015-12-08
ok i made the box but i still don't know how to wire the dpdt switch at all. did all the soldering but that. can someone draw the switch wired for me?
ikw (author)2015-07-13
Is there a different capacitor I can use instead of the 0.1 uF? I can't seem to locate one locally?
LeanneL1 (author)2015-06-03
Just a tip regarding the battery, you can get jack sockets with two terminal that link when the jack plug is inserted. They can be used to power the circuit only when a jack is plugged in.
I_HATE_LOSERS made it! (author)2015-05-10
this is what I got, thx for the tutorial
drewb3739 (author)2015-03-10
Which capacitor controls the tone?
nefcat (author)drewb37392015-03-12
I think you mean potentiometer. The 5k is for gain. The 100k is for volume.
drewb3739 (author)nefcat2015-03-14
I mean bass cutoff
Anargopunk (author)2015-03-04
hey, one question, what happens w/ the black audio jack cables??
nefcat (author)Anargopunk2015-03-10
you plug them to the ground
apawar8 (author)2015-03-09
Do any one did this project on breadboard??
I need your help pals !!
ranjam made it! (author)2015-02-13
If you look at the schematic, it's a Fuzz Face. Now, in a few minutes with Google you'll find a million web sites showing how to build it, mods to tailor it to your tastes, parts substitution, etc. Even some sound clips.
stanford.todd; Yes, what would have been nice is a 'lesson' on how to have every part 'line up' so you don't have a plate of spaghetti, with wires everywhere, or parts 'criss-crossing', adding RF interference. In other words, a little tip or two on laying out the parts and wiring so everything is super compact, with minimal leads. Even just a close up photo of how 'randofo' made his build line up on the perfboard. My own build has RF interference, but apparently many commercial Fuzz Faces had the same problem. Of course there mods to try and eliminate this.
Still a fun build. Mine has NO perfboard; all the parts are just 'flying' in mid air, soldered and tacked together, with the leads cut as short as possible. Still works like a charm after a few mods.
Who can give a better explanation of how to make the circuit. I'm so confused.
averycrookedvulture (author)2014-10-11
Wait, the video shows it being played and there is virtually no fuzz?????
EricS3 (author)2014-09-12
Could I please see how to actually MAKE the circuit? It's not "nice" to show everything except what we actually need to know. Totally useless demo. Really. I went out and bought the components--this list being very helpful,thanks--only to find the instructions part TOTALLY USELESS. Are you working for Radio Shack? IF so, I will never go there again.(Radio Shack, if you're reading, don't let this as#&*(%le represent you)
ClarkM1 (author)EricS32014-09-18
I agree, everything is great but a vid on building the circuit would be great.
ClarkM1 (author)2014-09-18
Your schematic isn't drawn correctly. You should have dots on the connections which makes it slightly confusing to build. But nice instructable!
pedrovai (author)2013-10-02
Could you post the straight fuzz circuit path. I want to build a simpler circuit with fixed volume and gain?, absolute beginner soldering here.
jlaframboise (author)2013-08-31
Ok, the model numbers provided and description of the components are not what you receive if you go into a radio shack OR order from radio shack online for the following components:
0.1µF 50V Hi-Q Ceramic Disc Capacitor (Model: 272-135 | Catalog #: 272-135)1/4" Mono Panel-Mount Audio Jack (Model: 274-255 | Catalog #: 274-255)
for some reason no matter what you do, you will receive Model Numbers 272-0135 and 272-0255.
You will receive a 500WV Hi-K Dielectric Capacitor and a Stereo Phone Jack instead of the components in the schematic and in the "go get stuff" list. I have tried to get the correct parts through radio shack for over a month now.
And I agree with Antonye, there aren't very clear instructions provided with how to put this thing together, especially for a beginner. An instructable should do just that, instruct. There is nothing mentioned about wiring in the components or what guage wiring to get. Board placement would also be helpful for someone with no experience and this is the first project they want to build.
Antonye (author)2013-08-30
Very unclear instructions to follow if you aren't more advanced in electronics. Are the PDF instructions more step by step for what connects where and is soldered in connection to what? Looks great, my boy went out and bought all of the components and now he is asking me to help him put it together. Building the circuit board as per the schematic is ok if you can read that ok, but I can't. I realise my boy should have researched this more before he bought all of the components, but I think he believed there would be more step by step instructions. Can anyone help please as he is really keen to build this, has spent all of the money and now we are unclear of how to put the circuitry together without more clear step by step component connection instructions.
jlaframboise (author)2013-07-30
Do you have a model # for the 0.01µF 50V 20% Hi-Q Ceramic Disc Capacitor. I was able to find a 500V that matches the model # listed in the above "you will need" section. I have model #272-0131, is this the correct capacitor?
marshy664 (author)2013-05-27
my project is putting out a lot of buzz when i turn on my amp. Is this supposed to happen? P.S this is the first pedal i've built.
randofo (author)marshy6642013-05-28
Yes and/or no. It depends what type of "buzz."
Does it do this with the clean signal? If so, then you have a problem.
Try adjusting the knobs and trim pots. Does that get you a more pleasing sound?
kimjames229 (author)2013-04-30
Would it be okay to use a breadboard so that I could avoid soldering as much as possible, as I am a beginner in electronics..?
randofo (author)kimjames2292013-04-30
Yes. You run the risk of components or wires falling out and maybe there being a little static, but otherwise I see no reason why you could not.
poplar tree (author)2013-03-18
hi all. i've begun to build the fuzz! but alas i have hit a brick wall already. this is my first project besides a theremin kit. i don't know much about electronics. i was wondering if someone would post some good picks of their finished project, as pics are about all i'm going on. learning to read schematics as i go, so hopefully something will click during the process. cheers!
brocowski (author)2013-03-12
oh and the dimensions for the box are 120 x 95 x 35mm i believe
brocowski (author)2013-03-11
hey if your trying to find the project enclosure he uses and the stomp switch he uses you can order bother from sparkfun.com. just go their website and type in the seach box "stomp" and hit enter and you see two metal project enclosures and the stomp switch
Mr.Pockets (author)2013-03-06
what are the dimensions on the box?
tykal123 (author)2013-03-05
Hey sick pedal! I want to make one myself but I was just wondering, if I use a 33uF 16V capacitor does it matter?
softenersreviews (author)2013-03-02
Thanks nice info really informative.
About This Instructable
585,733views
769favorites
License:
Bio: My name is Randy and I am a Community Manager in these here parts. In a previously life I had founded and run the Instructables ... More »
More by randofo:Large Motor ProjectsRemove a Wheelchair Motor BrakeBuild a Robot
Add instructable to:
