The version I made to Instructablize is shaped a little differently, and the construction is better. Neither used a pattern, I drafted the pattern directly onto the fabric before cutting. If you have a pattern for a coat by all means use it, but if not I am including a brief description of how to draft this one. (Note that a coat with a collar presents difficulties for a reversible garment - if you're not that experienced yet I suggest not using a collared pattern.)
Remove these ads by
Signing UpStep 1A note on fabric choice
Buy about 2 to 2-1/2 yards, unless you are very big or very small, or the fabric is very skinny. If you're using a commercial pattern, follow its suggestions, otherwise if you're not confident of your yardage estimate, you may want to draft a paper pattern first and lay it out to see how much fabric it will truly need.
9
comments
Add Comment
T3h_Muffinator
says:
rachel (author)
says:
=SMART=
says:
puffyfluff
says:
caitlinsdad
says:
gmjhowe
says:
Add Comment
