Introduction: G- 45 Assult Rifle
This is my best gun it has Awsome power and range, good accuracy and rate of fire, detachable magazine, high caliber bullets, strong build smoothe grips, textured butt,
and trigger gaurd
i would like to thank oblivitus and his z35 for the basic stock and rail designs as well as some insparation to the magazine
parts:
connectors
white: 20
blue: 22
yellow 111
orange 31
green  18
red  34
grey (2 joint) 5
grey (1 joint) 19
black( half-hole one joint) 2
tan clip 31
blue clips 8
y clips 23
rods
black 1
grey 2
yellow 5
blue 44
white 79
green 230
spacers
grey 19
blue 7
oddities
# 18 elastics 19
some duct tape
Step 1: 1-26
1. make 2
2. make 2
3. make this
4. get these
5. assembal 2 of the panels with the blue rods
6. add the gray piece
7-8. add the other two panels
9. build this
10 attach the peice, this is the hardest step, i recomend pulling the layers apart as much as you can and putting the orange peices on one at a time and squishing them with the panels,
for the white bit you can rotate the panels to make room
11 get these
12 attach as shown
13 build this
14 attach
15 build this
16 attach
17 build these
18 attach as shown
19 build this
20 get these
21 assembel on gun
22 build this
23 get these
24 assembel on gun
25 get these
26 attach
Step 2: 27-50
1. build these
2-3 attach
4. build this
5. attach
6. get this
7. attach
8.build this
9 attach
10 build this
11 attach
12  get these
13-14 attach
15 get this
16 attach
17 get these
18 attach
19 build these
20-22 assembl
23 get these
24 attach
Step 3: 51-76
1 get these
2 attach
3 get these
4 attach
5 make this
6 attach
7 make this
8-10 attach
11 make these
12-13 attach, the pressure between them holds them on
14 make 2
15-16 attach
17make this
18 make these
19 attach
20 make these
21 attach
22 the compleated part
23-24 make this
25 insert the parts make sure the blue rod on the trigger goes throught the block above it
26 close the handel
Step 4: 77-102
1 get this
2 attach
3-4 make this
5 attach
6 make this
7-8 assembel
9 make this
10-11 assembel
12 get these
13 attach
14 get these
15 attach
16get these
17 attach
18 get these
19 attach
20 make this
21 attach
22 make these
23 attach
24 get these
25 attach
Step 5: 103-129
1 make this
2 attach
3 get these
4 attach
5 make this
6-7 attach
8-18 make this
19-21 attach
22 make this
23 attach
24-25 make this
26 attach
Step 6: 130-156
1 make this
2 attach
3 make this
4 attach
5-6 make this
7-8  attach
9 get these
10-11 attach
12-13 get elastics 2 groups of seven
14-15 attach
16 make 2
17 make 2
18-19 attach
20 get these
21-22 attach
23 make this
24 get this
25 attach
Step 7: 157-163
1 Make the bullets
2 insert the bullets
3.make this
4 put it throught the holes
5 add tension
6 insert
To shoot  the gun, insert the magazine, pull the pin, pull the ram back untill it clicks, aim, pull the trigger
