I have a late 80's VW and the gauge cluster has 5 dummy LED locations underneath the other warning lights.  Well I was tired of the m not doing anything, so I decided to do something about it.  I came up with the idea to put a lateral gravitational force mater (G Meter)  in there place.
Step 1:
Gather up the needed supplies
If you wish to use your Arduino:
1- Arduino
5- RedGrenBlue LEDs (Mine are common anode)
1- Project box (if you don't want it in your dash)
1- 9v Battery
1- Accelerometer (I used ADXL 335 from adafruit)   http://www.adafruit.com/products/163
1- piece of Perf board
5- Resistors 1K ohm
5- Resistors 500 ohm
And some small wires for jumpers.
All parts needed if you wish to make it standalone:
1 -Circuit Board
1- ATmega168/328
1- 28 Pin socket
5- RGB LEDs (Mine were common anode)
5-Resistors 1K ohm
5-Resistors 500 ohm
1- 16MHZ Resonator
1- 104 cap
1- 10uf cap
1- 3.3v rg. (LM1117T)
1- ribbon cable
1- header connectors
1- Acceleromoter
1- 9v Batt. Connector
Here is the picture of the wiring needed for a breadboard setup.
The orange wires hook to the 500 ohm resistors and then hook to the RED LED cathode.
The Green wires hook to 1kohm resistor the hook to the GREEN LED cathode.
The common anode is hooked to +3.3v
X axis output of ADXL335 goes to PIN 0  (Picture is slightly different)
+3.3v and Gnd are hooked to power and ground pins of ADXL335
The AREF pin on the Arduino is hooked to +3.3v
infared067 says: Jun 5, 2012. 11:18 AM
For this to be accurate, wouldn't the accelerometer need to be place very close to the center of gravity?
Vrooooooom says: Apr 8, 2012. 12:18 PM
I wish I had a car with useless dash gauges! LOL
andamas says: Mar 16, 2012. 5:23 PM
I knew that dash as soon as I saw it! I had an 84 Jetta GLi, man I miss that car, so much fun to drive.
dagaherz says: Feb 16, 2012. 9:09 AM
And... what about the battery?
Could you adapt the project to work in 12V or 5V to get power from the car?
Good idea...hummm my car has "lazy spaces" too!!!
bhouston (author) in reply to dagaherzFeb 17, 2012. 8:01 AM
If you want to use the arduino I suggest using a USB 5v adapter or a 9v battery. If you use the board I designed it has a 3.3v regulator that will let you power it from car's power supply.
Machine in reply to bhoustonFeb 20, 2012. 10:28 PM
The illustration of the breadboard, connections and Arduino is very nice, what software is that, please.
I'd like to use that same style of illustration for my Instructables (yet to do one).
bhouston (author) in reply to MachineFeb 21, 2012. 8:02 AM
It is Fritzing. It is free and REALLY easy to use.
http://fritzing.org/
imperio says: Feb 16, 2012. 9:52 AM
a G-meter in the car what is the use?
bowmaster in reply to imperioFeb 18, 2012. 4:04 PM
Well, if you know what how much lateral acceleration your vehicle can pull without slipping, you can use a G-meter to turn as fast as possible.
kikiorg in reply to imperioFeb 16, 2012. 2:02 PM
You clearly don't drive fast enough. :) :)
(Of course, the better question is, "what use is a G-meter in a late 80's VW." :) )
bhouston (author) in reply to kikiorgMar 20, 2012. 2:18 PM
To answer the use of a G meter in an 80s VW- My brother jetta is currently pushing close to 350Whp. :)
imperio in reply to kikiorgFeb 16, 2012. 2:21 PM
it's true! I drive always at a speed below the speed of light
Epimetheus in reply to imperioFeb 16, 2012. 12:43 PM
... why not?
Fo55ilise says: Feb 17, 2012. 1:04 AM
I like this idea but won't build it - it would only give the wife something else to complain about.
Machine says: Feb 16, 2012. 6:58 PM
How about adding a voice warning:
Level 1 says "Pathetic, can't you do better?"
Level 2 says "Marvellous, now she's beginning to tip."
Level 3 says"Yippeeee, nearly on our side."
Level 4 says "Call an ambulance and a tow-truck."
zmashiah says: Feb 16, 2012. 2:02 PM
Very nice!
I am actually building one myself with small Dot-Matrix display and ADXL345 sensor.
As for powering the unit, The boards specify 12V as their maximum supply voltage, and in the car the voltage can get slightly higher (13V is not uncommon), so I would refrain to directly power it from the 12V, but you could easily use a USB car charger to get 5V or put a 7805 regulator.
Machine says: Feb 13, 2012. 7:29 PM
That is a very nice idea.
Maybe it should make sounds too, the higher the G the higher the pitch...
Epimetheus in reply to MachineFeb 16, 2012. 12:44 PM
That would be helpful in competing acrobatic airplanes but I think it would get really annoying really fast =P
askjerry in reply to MachineFeb 16, 2012. 7:26 AM
Yeah... like that would never get annoying... :-o
(Just bustin' on ya)
bhouston (author) in reply to askjerryFeb 16, 2012. 8:07 AM
Yeah I thought about that, and that's why I decided to install an off switch. :) I figured during the day wouldn't be bad, but a night it would really be distracting.
bumsugger says: Feb 16, 2012. 12:14 PM
Good idea for a novelty effect on my 1000cc Honda!
apzeiro says: Feb 16, 2012. 10:34 AM
What car is this?
I had in the past one here in Brazil. It had this same panel, It was called VW Gol 1991.
mikesters says: Feb 16, 2012. 10:28 AM
great, if I still had my golf II G60 I would install it there too :-)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
