G5 Mac Power Supply to ATX Mod
12,405
20
4
Posted
Introduction: G5 Mac Power Supply to ATX Mod
Converting a Mac Power Supply to ATX motherboard its no so hard to do. On the Picture above there is a ATX power supply on the left and a Mac on the right. The connectors on the power supply are different for the 2 computers but the cables are color coded equally.
Step 1:
Here is the diagram for the 20 pin & 24 pin Connector, most computers now use 24 pin connector.
Step 2: Diagrams of Pin Out
Here is the diagrams of the pin out for the ATX Motherboard.
Step 3: Welding Process
On the ATX power supply you have to cut the cables close to the PWS Mother Board.
On the Mac PWS you will cut the end of the connector.
Now match the cables by color.
Yellow = 12VDC
Red = 5 VDC
Orange = 3.3 VDC
Black = Ground
White = 24 VDC (Mac)
Step 4: Test
Testing the Power Supply with an old ATX Motherboard.
Step 5: Final Result
On the Mac PWS you will find a White cable = 24 VDC you don't need to use this cable for ATX Motherboard.
Use heat shrink on the cables that you are welding to prevent a short circuit.
Do not use electrical tape as it may fall off and can cause a short and burn your PC or cause a fire.
Have in mind that the Mac PWS only provide 460 Watt.
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    3 Comments
    thats all nice and everything but my mac psu has no cables and that box is full and it's rated 1000W !
    -12 VDC, What 's Color?
    Blue, usualy dark
