GAINER v1.0.0
GAINER v1.0.0
GAINER is a reconfigurable I/O module for education. GAINER environment consists of a hardware I/O module, a firmware for the module, software libraries for Max/MSP and Processing and optional hardware modules (called "bridge"). For details, refer to the following URL: http://gainer.cc/
Step 1Check components
Check components
The BOM (bill of materials) list is available at http://gainer.sourceforge.net/gainer_v1-0-0_bom.pdf
If you purchased all components, please check to make sure before starting to assemble.
10 comments
Feb 24, 2008. 9:37 PMrecon506 says:
correct me if im wrong, but basically this device ca be used to program/reprogram IC's. also, the BOM is kinda skewed, i mean it shows .371 of a circuit board. WTF??
Feb 25, 2008. 3:54 PMrecon506 says:
Sorry about the awkward wording... Well I went to the Bill of Materials you linked to, and I saw that the circuit board, which cost around 42 dollars, was listed in the amounts column as ".371". That made absolutely no sense because it should have said 1 circuit board. anyways, it's just me being picky. You didn't answer my question of whether this module could be used to reprogram I/C chips to work in other projects. -Recon506
May 31, 2006. 11:35 PMMyself says:
Browsing all the old projects and finding some gems back here! I just picked up a "serial wombat" and it looks to be very similar in concept -- a programmed microcontroller that'll probably never run independent of a PC, rather it acts as an I/O expansion. The wombat seems aimed at a newbie crowd though.
Apr 6, 2006. 9:53 AMnvillar says:
Electrolitic capacitors, like the LEDs, also need to be soldered in the correct orientation. In this case, the capacitor should be soldered with the long leg to the left side of the board, and with the white vertical stripe to the right of the board (if you are facing the board so that the button is at the bottom). Talking of the button - it should also be soldered in this step!
Apr 6, 2006. 9:42 AMnvillar says:
Remember the IC notch! Both ICs and the sockets the plug into have a semi-circular notch at one end. This is used as an orientation guide, to see in which direction the IC should be plugged into the socket. In this case, make sure to solder the socket with the notch facind the USB-connector end of the PCB.
Mar 23, 2006. 8:03 AMapophene says:
Brilliant! I am really excited about this project. I use MakingThing's Teleo modules with Max/MSP already, but this looks to be a great way for artists who aren't afraid of soldering guns to get a little closer to building their own tools (besides being less expensive). Speakings of soldering, that little FTDI USB module looks like a bit of a challenge--is this something students new to electronics can reasonably expect to make? And there'll be more in the way of tutorial material soon? Love the Breadboard Band!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:kotobuki
I'm much interested in creating something with electronics and software technology.
