3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
GARDEN RAINBOW LIGHT
     HOW TO MAKE A LIGHT THAT LIGHTS UP AT NIGHT IN RAINBOW COLORS. This  novel light has a light source from a LED  [light emiting diode] commercial sunlight  charging battery source.
These  lights-on-a-stick are available from any garden supply store for as low as $1.25  and  have a self contained ni-cad  [ nickel-cadmium] battery that charges up during the day and automatically turns the  light   on at dusk.This DIY adds a novel twist- a CD that dissipates this light in colors of the rainbow.
Step 1MATERIALS and TOOLS
MATERIALS and TOOLS
MATERIALS-
Outdoor night-lite. supplied  with a battery, charging array, and a mounting  rod. The rod will not be used here as this array will be suspended from a string. Prices; $1.25 to $3.99  . I used the lowest cost unit.
Nylon string(fishing line is used here).Stretch cord 1mm size is best.
Paper clips (3ea).any size will do.
CDs any source but most vivid are lowest cost [about 20cents ea.] Movie or music discs  ok.
Wire, any available or craft store wire spools.about 2 feet.
Thin plastic can be any old credit card or a used up gift-card. 1/2x2 in.size.
Urethane foam sheet  1/4 x 1/2x1 in. approximately.  Used in case  no hole drill is available. to mount the  string to the plastic light enclosure.
Glue- Goop and E6000 [r]  is  strongest and resistant to weather.Use adequate ventilation.
TOOLS-
Pliers
Scissors
Heat source to warm the CD plastic to easily cut.Hair drier  or space heater.
adhesive tape dispenser
Pick to punch holes in plastic
Dremel drill. with 1/16 to 1/8 drill bit. to drill the holes in plastic light  assembly.
1 comment
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:mistic
A retired electronics engineer -motorola. delveing into new craft ideas and contest entries.
