3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
GE Adora Lint Filter Cleanout
Step 5Unscrew the filter.
Unscrew the filter.
You should be able to turn the filter plug counter-clockwise.
CAUTION: Do NOT get over zealous and unscrew it all the way out right now, or you will have a ton of water all over you and everything in close proximity to the washing machine.
Position your catch basin underneath the plug and unscrew it just enough for water to start coming out. When you get close to filling up your basin, screw it back in to stop the flow of water. Empty basin and repeat. The pot I used is 4.5 quart, and I dumped it 5 times. So, there may be quite a bit of water that you have to drain.
If you have the washer riser installed, the tray is sealed plastic, so you could theoretically let it drain into there and deal with it from there, but it's easier to do it one pot at a time.
"NOTE": Don't dump this water down your sink. It's full of lint, etc., and could easily clog a sink or bathtub drain. Dump it in a toilet or outside.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:elvisisdead
