What is a Question?
Questions are a super-easy way to get answers from the Instructables community. Learn how to build, do, or make anything! You just ask a question and the community will provide answers. You choose the best answer!
Submit a Forum Topic! The forums are the place to ask questions, share a cool project from another site, find collaborators for your latest project, or discuss anything of interest to the Instructables community.
Do you have a lot of images to upload?
If you prefer to upload your images before you submit, then this is for you.
Remember to tag them so they will be easier for you to find when you are viewing your library.
You can also upload images when you are creating your posts.
Did you find a bug or have a suggestion for us?
We appreciate all the help our users give us in tracking down bugs and making the site better for everyone.
PhotosPhotos
Although the picture is poor, if you look inside the unit you will see a small shiny reflector that hides the bulb. If you place a flashlight in the microwave pointing up, it will be easier to locate the bulb. The reflector is simply a "pinch fit" into the unit. Sqweeze it a bit, making sure not to bend it and it will come right out where you can work with it.
Thanks a million for this! I have one question , what is the two prong object on the left connected to the two wires (1 red) ? I unplugged it by accident and spun it with the side of my hand. Will it make a difference how i reconnect? I dont want to have a "Lethal Weapon" moment and incorrectly connect the wrong wire.
Sorry I have been so late to reply. I can't remember the name of that part that got disconnected, but several years ago, mine failed and I had to replace it to keep the microwave working. At this point, you probably have already determined the how to reconnect it and have come up with a solution. I think it may have been called a thermocouple but I am not sure if there is a polarity to the device. I would guess not since the prongs are not different sizes. I'm glad this instructable helped and I appreciate your kind comment. I hope everything works out for you.
I have this same GE Advantium halogen microwave but purchased it in 1999. Model # SCA2000BBB 03. I was excited to see your post, joined up, and downloaded the pdf. My original "just light up the inside when the door opens" bulb went out several years ago and even though under extended warranty, the man who came to replace the bulb basically "gave up" after literally trying to take the whole right side of the unit apart . . . we knew where the bulb was but couldn't figure out how to get to it. I feared he would never get it back together (parts all over the kitchen!)
Rather than being "in the top", this bulb is visible behind a "screen" (holes in metal) on the right side of the interior as you look in. Can you please help me?
I found an exploded diagram for your microwave, but can't find any bulbs on the side of the unit. Hopefully, this diagram can help you get this challenge figured out. Can you post some pictures of your micowave interior? Good luck.
Here is the link: http://www.appliancefactoryparts.com/microwaves/helpcenter/breakdowns/ge/ge-sca2000bbb.html
Hi, Thanks for your reply. Here are pictures of the inside/right side of the microwave . . . . basically behind the control panel. You can see the bulb behind the mesh if you look closely.
I looked but couldn't find the bulb on the diagrams you sent . . I am thankful but still not sure how to fix this thing.
Thank you! GE was very unhelpful and made it tough to get a hand in there to change the bulb. You made it easy (and saved us the cost of a service call to replace a bulb!) and we appreciate having that info. Thank you again.
Thanks for the resource. Here is a good resource too: GE MICROWAVE OVEN Just click on one of the "browse subcomponents" links below after you open the page.
Got the bulb out (it was bad). Unfortunately discovered the small 1x1 piece of glass under it is broken. Any idea where to get a replacement? Part number etc
I consider myself lucky that I have only had to replace the bulb. I have never ordered any other parts. I have found that the Sears parts store both in town and online, can usually get me any part I need. Online, you might even be able to find an exploded diagram of your machine. Sears calls the machine something else, but they are basically identical.
Than you for the comment. As far as the fan goes...What I have noticed is that when 'I' use the Advantium for an extended amount of time, the fan comes on automatically to cool the unit (I cannot make the fan stop at all). This happens most often with foods that create a lot of moisture. As far as a connection with the micro-express mode...I have no suggestions. Sorry.
Thanks!
Thanks again!
Thanks so much!
