Step 2Repair Solder Joints
Take the drums apart, scrape the sealant off the solder joints, and start over. If yours are like mine the red drum is all but non-functional. I touched the wire and it just fell out. I believe this is partially due to wire-routing. There was quite a bit on tension on the wire set for the red drum head.
If you pull gently on the wires while watching the sealant carefully you can tell which wires definitely need repaired. Any movement indicates the need for repair. I did them all, 6 contacts is no big deal.
comment
Add Comment
Add Comment
