Step 3Cymbal Fix
The main problem here is the piezo element was not fully seated in the intended location. It appeared to have some sort of adhesive that was locking it in the place, albeit the "wrong" place. I decided rather than risk removing it and having to rework the mounting location or the element itself I would simply press it into place.
Because it had so play in the mounting the strike vibrations weren't fully transmitting to the element. I removed the cover, stacked a bit of foamcore (or cardboard, whatever you have) so that the cove just barely didn't seat.
After screwing down the cover, the foamcore added enough pressure to the element that it contacted perfectly and registered nearly exactly as well as the yellow cymbal.
(If I can edit this later I will get pictures. First Instructable so...)
comments
Add Comment
Add Comment
