3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Guitar Hero:World Tour Drum Repair
Step 6Final Thoughts
While these fixes are pretty easy, it would seem some sort of process improvement or quality control is in order on the part of Actvision and/or their suppliers.
It could be fixed readily at the manufacturing level, I think, but that begs the question of units already produced. The bumper-type units I fabbed could be easily made via injection molding with a bit of a slit clip at either end to avoid fasteners and drilling. Attach a sturdy rubber bumper to the apex and you're in business. Or pull the piezos themselves and remount.
There is the issue of crap soldering and wire management that would still need to be addressed. I submit that using tape instead of the sharp bends would be step one, better assembly of the elements and harnesses being step two.
Hope this helps some folks, If I can I will edit and add more pictures a little bit later. Happy warranty voiding! We makers don't need you anyway.
4 comments
Jan 28, 2010. 9:27 PMLeahloo says:
Awesome fix!  My drums work better than ever now. Thank you!  I'm almost embarrassed to say that I used some pieces of bamboo skewers and rolled up masking tape instead of the metal "springs".  I was able to push the skewers into each side of the foam and used the masking tape on top of the sensor and under the skewer.  I had to adjust the amount of masking tape for each sensor so they didn''t register when I hit the cymbols.  Works great!
Mar 20, 2009. 2:04 PMhawke777 says:
This was extremely helpful. My Rock Band 2 cymbals broke and I used some tips from here and also the following to fix it:
http://www.protoolreviews.com/how-to/build-it-yourself/repair-broken-rock-band-2-cymbals
What's cool is that the end result was better than the original, since the drums stopped double registering as well as missing the occasional note. It's now pretty much dead-on with every note, even through fills.
Dec 31, 2008. 3:29 PMjfragment says:
It helped me very much. Thanks. I had the red drum round censor lose it's adhesion to the pad. I tried scotch tape but that comes off after about a song of testing. My next test is super glue. Wish me luck!
Jan 2, 2009. 11:05 AMSpinozaQ says:
I would try a high quality epoxy to re-attach any piezoelectric elements. It will provide a little bit of flex and won't crack like other glues. Super glue may work... but I think it would crack over time from flexing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:RepairmanSki
