Step 11When You Eventually Finish Adding The Feathers...
iImage Information
When you are done adding your feathers, several hours, days, or weeks later, you can cover that ugly wire loop with the ribbon by bending it in half over the wire and hot gluing it. While you’re at it, you can add some rhinestones, glitter (I recommend buying a spray adhesive and then “dusting” them by throwing glitter at them), or trails of ribbons hanging from the mid-loop. You can also add feathers to the mid-loop, flowers, marabou, mirrors, etc. Keep in mind, however, that if you are not going to be adding straps, the support loop will not be visible as it will go inside your shirt (in which case you may want to just leave it covered in ribbon).
You can also add rhinestones, mirrors, etc. to the wings themselves by hot gluing them to your feathers or glitter with adhesive spray or Elmers glue.
