Step 5Design the Base
1. Cut your felt in half so you have two pieces (one for each wing).
2. Take one piece of fabric and fold it in half length-wise (or "hot dog" style as my kindergarten teacher used to say...)
3. Lay the folded piece of fabric under one side of the frame.
4. With your Sharpie draw an outline around the wire. The outline should be at least 4" thick and as long as the length of the wire to the support loop. It does not and probably should not be completely ovular, but should follow the shape of your frame. This will provide the base / support for your feathers. You can use a wider shape if you want your wings to be stronger.
5. Repeat with the other piece of felt for the other wing.
Add Comment
