Introduction: GLITTER BOMB
This is probably the greatest office pranks of all time. And its so easy to do.
Step 1: Supplys
Gather all necessary supplies.
Glitter bomb poppers are similar to confetti poppers used to celebrate New Year’s Eve, weddings, birthdays, or other holidays. Party poppers or crackers first appeared as British party favors in the 1840s.[5] Save money on poppers – and fill them with glitter – by making them at home. You will need:Paper towel roll cut in half or toilet paper rollGlitter (different colors)ScissorsA Stapler with staplesBakers twine or stringScotch tapeHot glue gun and sticksBeadsRibbons for streamersCardstockTissue paper
Step 2: Choose Your Crime Seen
Construct a trap door.
Glitter bomb poppers explode when someone pulls a string attached to a ‘trap door’.[6] Cut a tissue paper square that is large enough to cover the bottom of your tube (about 3 inches or 7.5 cm). Trace the end of the tube onto a piece of cardstock and cut out the circle. Use the hot glue to glue this circle to the center of the tissue paper square. Let dry for several seconds. Use scissors or a needle to puncture the center of the circle and thread an arm’s length of string or twine through the hole.
Attach the trapdoor to the tube.
Before gluing the tissue paper and cardstock trapdoor to your tube tie a bead to the end of the string, making sure it is on the side that will face the inside of the cardboard tube. Attach the trapdoor by using the hot glue to glue the edges of the tissue paper to the sides of the tube. At this point, your glitter bomb popper should look like a tube with one end sealed off, and a string ‘tail’ extending from the base.[7]
Step 3: Making Your Bomb
Decorate the tube and fill the tube with glitter. Be creative when decorating the body of the tube. You can wrap it in colored construction paper or metallic foil, or glue ribbons or streamers to the sides and bottom. Before sealing the opposite end, use a funnel or measuring cup to fill ½ to ¾ of the tube with glitter.
Dont be afraid to put to much glitter the more the better
Step 4: Almost Done
Add a cone-shaped top.
Turn your popper into a rocket by adding a cone-shaped top. Draw a 3.25 inch (8.3 cm) circle on a piece of cardstock. Use the scissors to cut this out, and then cut a single snip from the edge to the center. Pull the edges of the cut together until they overlap about 0.5 inches (1.3 cm) to form a cone. Stable the edges together.[8]Attach the top by punching two small holes just below the opening of the tube. Thread a string through the holes. Bring the two ends of the string together over the opening and thread them through a bead. This will help keep the string centered. Next, thread the string up and through the hole at the top of the cone. You can use this string to hang your popper from the ceiling or attach it to a string of garland.[9]
Step 5: Choosing Your Victim
Release the glitter. Pull on the string extending down from the trap door. This will cause the trap door to rip-off and cause the glitter to rain down on unsuspecting party goers.(Boss)
3 Comments
This is awesome!!!
WHERE DEM PHOTOS
Vote for me on the glitter contest
