Introduction: GPS for the Raspberry Pi: PiloT GNSS Tutorial
Picture of GPS for the Raspberry Pi: PiloT GNSS Tutorial
The PiIoT is a WAN communications board which provides an HSPA / 3G wireless interface for the Raspberry Pi. Conforming to the HAT specification, the PiIoT also provides location information using an on-board GNSS* solution.
*Please note: the optional GPS fuction is only available for the HL8548-G variant of the PiloT. Please see specification and/or related documents for more information.
Access further documentation and purchase information here.
The following instructions set up an NMEA feed over the Raspberry Pi serial port.
Ensure the PiloT is powered on by clicking here and following the steps listed.
Step 1: Connect to the PiloT Using Minicom:
minicom -D /dev/ttyAMA0
Step 2: Change the Speed of the Serial Port to 9600bps:
AT+IPR=9600
Change Minicom serial speed to 9600bps and reconnect by holding Ctrl + A, then 'Z' > 'O' > arrow down to 'Serial port setup' > enter 'E' > 'C'.
Press enter, then press 'Esc', then arrow down to 'exit' and press enter.
Step 3: Direct the NMEA Output to the Physical Serial Port:
AT+GPSNMEA=1,1,FFFF,FF
Step 4: Start GPS Output on the Serial Port:
AT+GPSSTART=2
(See Sierra Wireless HL8548 AT Command Guide for more details of GPS commands)
NMEA sentences should now stream from /dev/ttyAMA0.
Step 5: Stop Running GPS:
Open a Minicom session on /dev/ttyACM0 and enter:
AT+GPSSTOP
Close Minicom (Ctrl + A, then X > enter).
philgree (author)2017-09-20
These instructions didn't work for me. Here's what I did instead:
1. Follow the other instructables also from linkwavetech to setup access via usb (ports /dev/ttyACM0 through 4)
2. Fire up "minicom -D /dev/ttyACM3"
3. Within minicom enter: "AT+GPSNMEA=4,1,FFFF,FF " (you shouldn't need to play with baudrate settings for this)
Note: (the 4 signifies "current port" which in this case is /dev/ttyACM3 whereas 1 is UART1 aka /dev/ttyAMA0)
4. Also within minicom (although you might prefer to so this from /dev/ttyACM0 to avoid clutter) enter: AT+GPSSTART=2 to start GPS
5. As a basic test using minicom or gpsmon on /dev/ttyACM3.
6. Next, take a look at gpsd (sudo apt-get install gpsd). Once you've got that installed, you can view the data using cgps or xgps (sudo apt-get install gpsd-client).
About This Instructable
462views
10favorites
License:
More by linkwavetech:GPS for the Raspberry Pi: PiloT GNSS Tutorial Add 3G to the Raspberry Pi: PiloT TutorialAdd 3G to the Raspberry Pi: PiloT Assembly
Add instructable to:
