GSM Alarm System for Leaks Without Arduino
3,782
62
Published
Introduction: GSM Alarm System for Leaks Without Arduino
Hello.
  • In today's video we will do just such an alarm about the water leakage.
  • That will alert you with an audible signal Itself will block the water and call you on the phone.
  • You can also manually control the valves.
The scheme is simple and without AVR end Arduino
Detailed assembly and demonstration work can be seen on the video.
Step 1: We Need
  • One or two valves (valve with three terminals)
  • Old phone (I Siemens CX75)
  • A transistor IRLB8721
  • Resistor 2M
  • Relay 5 volts ( TRSB- 5VDC-SB-L15 or BT-5S 5V )
  • Buzzer HCM1206X
  • Diode SF18 or HER107 or FR104
  • Two buttons
  • Suitable housing
  • Four batteries
The scheme is very simple
Step 2: The Scheme Is Very Simple
Step 3: Attach the Scheme.
Step 4: Insert the Wires Into the Body
Step 5: Glue and Solder
Step 6: On Your Phone, Set Up a Quick Call to Your Number on the Button 9
Step 7: Phone Upgrade
  • remove the keyboard
  • disassemble
  • cut away the film on button 9
  • solder wire
  • cut off button 9
  • install the keyboard back
Step 8: Testing
Contact Sensor must be placed on the floor in the bathroom or in the kitchen.
Thank you for attention.
    • Clocks Contest
      Clocks Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
