3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
GTP USB PIC PROGRAMMER (Open Source)
This work includes, GTP USB (not plus or lite) .
The schematic, photos and PCB have been developed by PICMASTERS based on
some valuable works done before.
This programmer supports pic10F, 12F, 16C, 16F, 18F,24Cxx Eeprom.
Unfortunately, it works with only Winpic800 v.355.
We have succesfully tried it with some pics; PIC18F252, 18F2455, 18F2550,
18F2520, 16F84, 16F628 and 24C32 eeprom.
The best and fastest method of pic programming.
All you need (hex file, winpic800, schematic, PCB board in ARES)
are included.
You must program pic18F2550 with hex file by a classical programmer.
Just leave a good fedback for us.
Step 1Circuit scheamatic
circuit scheamatic
circuit schematic. You can see the type and value of the companents.
159 comments
1-40 of 159next »
Mar 26, 2012. 9:48 PMZ.K. says:
Where is the all_of_thedocumantries.rar file? All I get is a *.tmp file.
Apr 1, 2012. 1:34 AMpahexa says:
rename the file with (.tmp) = (.rar)
gud luck ..
Mar 18, 2012. 7:33 PManoukalex says:
Hello! Could someone please tell me what the firmware that works with this programmer? For whoever got from this page will not work.
Send it to me at: imalu@telecentro.com.ar
Thank you.
Mar 12, 2012. 12:39 PMmarcosviera says:
Excelente project. I will build it, and post my comments after.
Jan 30, 2012. 7:32 AMahmedsobhi says:
good,
Jan 3, 2012. 12:35 AMcomraex says:
Hi!
Dear Sir,
I just built "GTP USB PIC PROGRAMMER".
At first start-up surprise .... (pinul9-ULN2003 = not connected). Design mistake.
Step two: driver GRABADOR TODOPIC-USB is not recognized by Windows XP Professional.
What to do?
You ever work?
There is another design mistake, incorrect component values ?
There is another USB driver?
Thank you.
Happy Birthday!
D. Sandu
Dec 26, 2011. 3:08 PManoukalex says:
Hola! Lamentablemente reitero, ahora en español, el programa HEX que obtuve NO FUNCIONA!!!. No se cual es la trampa. Habrá que pagar para obtenerlo ??? Una lástima, realizé un gasto considerable y una gran pérdida de tiempo. Recomiendo construír el GPIC USB en SITIONICA. Es ARGENTINO y funciona, no se engaña a nadie y si tienes un problema o duda el autor te responde inmediatamente, como debe ser.
Lamentable!!
Dec 10, 2011. 9:43 PMdevilsnight says:
nice work
Apr 16, 2011. 1:17 AMrtabanao says:
Hi,
I successfully built this programmer but wondering why I can't program 18F2455? It can't even identify this chip!
Tested on PIC16F84A,16F628A,18F877, 16F76, 18F4550, 18F/LF452 but everytime I tried working with 18F2455 DEVICE: UNKNOWN is the result...:(
Dec 7, 2011. 3:21 AMefdat says:
since you did it, which is nice 4 u, now i kindly request you 2 pliz post the componets list. Ill be glad thanks nys time ;-)
Nov 18, 2011. 7:38 AMcombat99 says:
Thanks!!!
Nov 5, 2011. 3:37 PMTIGRE596 says:
Thanks!!!
so good!!!
Oct 31, 2011. 7:58 AManoukalex says:
Hello! I built this programmer, but not working. When connected to my laptop with Win XP or Win 7 USB ports do not recognize.
The firmware that is loaded in the 18F2550 "GTP_USB.hex." Is it right?
"GTP-USB-MAIN-PCB.LYT" opens with Proteus?
Thank you very much,
Claudio.
Oct 17, 2011. 10:52 AMal1b says:
in the schematic there are two diodes without any name or values, 8 1n4148 but dunno what are two diodes near the zif board connection...
thx already
Oct 9, 2011. 5:35 AMefdat says:
please which software do you use?
Oct 6, 2011. 7:08 AMtechnicum says:
Does anyone has got a component-list of this project?
Oct 1, 2011. 10:30 AMjahanzeb.gul1 says:
Hello guys i am beginner Engineering student, can someone tell me that either it works fine on PIC18f4520 or not because i have an assignment of building the kit circuit and i want to build a usb powered instead of serial port.
Thanks !
Aug 6, 2011. 10:48 AMpascalbianca says:
Indeed nice work , but what Shani_17pak says, it was nice if you placed the used components on the pcb's so the people don't have to search where to place the components.
But keep up the good work.
Jul 24, 2011. 3:18 PMpiratus says:
where is the composant list ?! thanks ;) !!
Jun 24, 2011. 5:52 AMshani_17pak says:
nice work! but 1 think i need that you do not provide us that the component pcb layout that which component is solder on which hole. plese send that simple layout so i done my work thanks dear. i need it becuse i am new in this fieald and a hobbiest kindly help me out. bye (shani_17pak@yahoo.com)
May 12, 2011. 6:13 AMratgod says:
Does anyone know how the voltage boost configuration works in the schematic, I'm familiar with that configuration working with AC coming in where Vcc is connected and RAx's being ground.
I assume there must be some kind of ripple or pattern generated on the RA0-3 pins.
Any ideas?
May 6, 2011. 9:19 PMdaniel aziz says:
hello every body,
thanks for that great programmer I'm in the process of making one of these and yours seams to me very nice there is one problem however my English isn't so good so if you can write the parts names i couldn't find any "tantalum" cap in the schematic so i hop if you can help at this and make a text list ??
Apr 13, 2009. 8:02 PMbutch_pastor says:
Hi Keolerea, I just finished assembling the GTP USB and programmed the 18F2550 via a JDM2 Programmer. I tested it but WINPIC800 did not detect the hardware with a message "Failed to open Ind. #0". I implemented the hardware settings but WINPIC800 cannot saved the settings. Was copying the WINPIC 800 Folder to Program Files and launching it was all I had to do or did I miss a procedure. I also revised the PCB layout such that the final PCB was just a single sided type although a little bigger than the original design.. Hope to hear from you soon. Have a nice day.
Mar 7, 2011. 3:47 AMsurfies says:
Hi Butch_pastor,
I have the same problem youve got , did you manage to sort it out yet?? Please let me know.
Mar 7, 2011. 4:29 AMbutch_pastor says:
I decided to stop further testing of the GTP programmer and has been successfully been using the USBPICProg of Frans Schreuder. You can check out this programmer at www.usbpicprog.org.
Mar 7, 2011. 5:47 AMsurfies says:
Thanks for the reply will check it out
Mar 10, 2011. 4:19 AMsurfies says:
Hi Butch,
Man that programmer of Frans Schreuder looks like Chinese to me. Building it will be piece of cake, but all that setups makes me deurmekaar. Can I just program the IC in the programmer with a hex file ( which one of the hunderd files ?) , without the bootloader ?? How did you go about it?? Would like to hear from you.
Mar 10, 2011. 6:08 AMbutch_pastor says:
Once I was finished with the assembly and all drivers, bootloaders and software installers downloaded, I start with the loading PIC18F2550 with the bootloader boot.hex and the firmware using another programmer (a JDM will do). Then I insert back the PIC to the newly assembled programmer that's it.
Then I install all the USB Lib files to PC (http://sourceforge.net/projects/libusb-win32/files/) and then install the Programming Software.
In selecting the files needed to be installed, choose the most recently released version.
That's all then you can start programming target PICs.
Mar 11, 2011. 1:07 AMsurfies says:
Thanks will start building, will let you know how it goes. There is somebody on Facebook, MICROCHIP group, also looking for a USB programmer, but he waits for me to finish something succesful.
Feb 7, 2011. 11:54 AMbeckhamjohny says:
work on windows 7?
someone know if work on windows 7?
thank's all
Jan 16, 2011. 1:11 AMgfaycal says:
think you
Jan 14, 2011. 7:31 AMNibu says:
Sir,
I would like to know how does this programmer works or From usb how does data streamed into this progarmmer board and how does this programmer programs the PIC............
Thanks in advance sir...............and gr8 work
Dec 23, 2010. 11:13 AMbingladesas says:
how program 18F2550 , in scheme ? or to another and then solder to the main ? thanks
Dec 23, 2010. 2:40 AMwangqh says:
Thanks!!!
Dec 23, 2010. 1:02 AMninz0 says:
ok, thanks...I resolved the problem...now it works very fine.
I need to buy a zif 40pin socket.
do you know if there is a web-site that offers the zif as FREE SAMPLE ? :)
bye
ninz0
Dec 7, 2010. 1:48 PMninz0 says:
hi guys!
there is anyone that tested this programmer?
I have a problem with Windows Xp, it doesn't recognize the programmer.
in Computer Managment--> peripherals I see the GRABADOR TODOPIC-USB but it isn't installed correctly.
can anyone help me with this issue?
thanks all and thanks to keolerea! :)
Dec 20, 2010. 11:52 PMvin00777 says:
update the driver through device manager from the driver gtp usb folder
Dec 18, 2010. 3:01 AMtharindu1st says:
please add single sided pcb design in this board
Dec 16, 2010. 6:48 AMerdogan.55 says:
an excellent work, his mind health. vesselam
Dec 12, 2010. 8:55 PMChen Jackie says:
so good!!!
1-40 of 159next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:keolerea
