Gakken Theremin Kit Hack
Here are instructions to do some basic hacks to the theremin kit that you can buy from Make. True, there are already directions to do both of these things in the accompanying magazine, but what sets this how-to apart is that it is in English. If like me you can't read Japanese and unlike me, you couldn't figure out what to do from the pictures alone, this should help.
Basically, what I am doing is adding an audio out jack and also a bigger, sturdier telescoping antenna. This is a great improvement on the original.
Step 1Go get stuff
Go get stuff
You will need:
Gakken Theremin Kit (from Make)
A power drill
A mini screwdriver set
A mono jack with switch
Something with a telescoping antenna
A solder setup
Some extra wire
Assorted hardware
12 comments
Jun 15, 2009. 10:25 AMearnst2w8 says:
what kind of headphones are they? i really like them :P some retro stuff :D great instructable!
Jun 16, 2009. 12:35 AMearnst2w8 says:
yeah, but i really like the sound cancelling headphones you used, where did you buy the sound canceling headphones ( without the speakers inside) wich store? or the web? thanks
Jul 20, 2009. 3:51 PMphant0m_sp00f3ra says:
i was gonna ask that exact question. :D
Jun 15, 2009. 5:56 AMSpokehedz says:
If you find the audio-amplifier circiut (should be a simple op-amp) you might be able to tap into the signal and get line-out voltages from this.
Jun 15, 2009. 3:24 PMSpokehedz says:
Always good to follow the instructions first, and then do your own after. Give you a better idea on what's going on.
Jun 15, 2009. 2:19 PMconrad2468 says:
Is it possible to make a long range thermin?
Jun 15, 2009. 6:29 AMcrapflinger says:
a pox on digital theremins! it's not a real theremin (though...that's obvious with this one)...the sound is never as good as an analog one
theremaniacs make a nice analog single antenna model that's pretty cheap (relatively)...i got one of these kits for my dad and made my own case/mount/whatever for it out of a cigar box and a little bust of chairman mao...sounds great! http://www.theremaniacs.com/
Jun 14, 2009. 1:10 PMalex-sharetskiy says:
very cool!
Jun 14, 2009. 7:57 AMdatenkrieger says:
Nice one, very detailed. One thing might be important, the output signal from the jack is very strong, its a good idea to use headphones with volume control like i see in the picture above. I can use Ipod speakers on it without turning them on. I didn't dare to hook it up to an amp, i think it might blow it. I'll build a mixer first.
Jun 14, 2009. 2:59 AMgmjhowe says:
Nice! I think you did a great job modifying it. I have always wanted a theremin. Goes to waste money on one..
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1972
Author:randofo(Randy Sarafan loves you!)
I am the author of the book '62 Projects to Make with a Dead Computer' and Community Manager here at Instructables. I'm always sharing tons of awesome projects. Subscribing to me = fun and excitement!
