Custom car mount for your smartphone
 by at0mbxmb
Featured
Cad files are available here: http://www.thingiverse.com/thing:24315
Feel free to modify the design to fit your particular phone or car.
_________________________________________________________
So, I bought a Galaxy Note recently. I’m not sure if you’re familiar with the Note, but in short, it is a Really Big Phone. Soon after, I bought it a sweet sweet wallet case, and it became Even Bigger. (Bigger, yet awesome, and now capable of holding my credit cards!)
This caused a bit of a problem in situations where I was used to having a more “standard-size” phone. Particularly, this became an issue while driving, as the phone no longer fit into the convenient cubbie in my car. I considered buying a car mount, but they were all slightly less than ideal in a number of ways, and to top it all off, would require me to take my phone in and out of its awesome wallet case multiple times per day. Oh, what’s a hacker to do?
Why, BUILD HER OWN CUSTOM CAR MOUNT, of course!
This device is intended to snugly fit a Galaxy Note phone in a Spigen wallet case. The back of the mount is custom-designed to fit in an empty compartment in my Hyundai Accent, and can be changed to fit whatever location you'd like. This design also features a hinge to enable the user to point the phone at either the driver or passenger, for radio or map usage.
This particular design is easiest to build with a laser cutter, but a jigsaw or other cutting apparatus would likely work just fine.
I recommend reading through the instructions before making any cuts to your material. Many parts of the design are variable and depend on your specific materials and setup.
Step 1: Pieces you will be making
On top: Small half-circles fit into the horizontal slots in the acrylic rectangle and in the large wooden backpiece.  Run the bolt through these to create the hinge.
V-shaped items show on either side of the backpiece are the prongs that pressure-fit into the cubbie in your car. They fit snugly into the vertical slots in the acrylic rectangle.  (The acrylic rectangle is designed to fit inside a cubbie under the radio in my Hyundai Accent.  You will likely need to re-size this piece to fit your particular car.)
J-shaped pieces stack on top of one another (later reinforced with glue and wood screws), and adhere to the bottom sides of the backpiece to provide support for the phone itself.
Note the two acrylic rounded rectangles at the center bottom.  These were later changed to wood for aesthetic reasons.
FrozenIce says: Oct 25, 2012. 9:25 AM
Nice!!
Nice Note, as well!
I am actually considering buying one myself! Do you mind if i contact you about your opinion on it? That would be very helpful for me :) thx
rkelle7602 says: Oct 21, 2012. 9:21 AM
Wow! I made one very similar to this for my Sebring's little cubby hole in the center dash. My friends make fun of it but it works great! Mine is even a little more primitive as it just wedges perfectly into the cubby hole but it's exactly what I was shooting for. Congrats on making it to the front page of the newsletter!
bytehead says: Oct 21, 2012. 8:43 AM
Good job!
I bought an iOttie for my Note (great phone!).
I don't have a case for it, and found that, while technically it is supposed to fit in the iOttie, it really doesn't. I trimmed the rubber grippers down almost to the plastic to get it to be able to slide in without taking the iOttie off the windshield. And I'm still hitting the power button every time I insert or remove it. With a case? Not going to happen!
I love this.
chaitanyak says: Oct 21, 2012. 6:51 AM
beautiful. good call on the wood stain
MonkiMan says: Oct 20, 2012. 4:02 AM
That Spigen wallet case is AWESOME, thanks for bringing it to mty attention (also great instructable : )
Winged Fist says: Oct 19, 2012. 9:48 PM
Really nice job! I've been thinking about making something like this, and you gave me some great ideas... 5 stars;-)
fungus amungus says: Oct 19, 2012. 12:51 PM
How'd this one slip by? It's awesome!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
