Introduction: Galaxy Note Case-able Dock
Whipped this up for my wife.
She recently got the Samsung Galaxy Note in place of her iPhone and immediately wanted to case it in a wallet style case as she aimed to carry all her financial ends along with the Note making it the primary item to pull from her mini purse. The issue came when time to charge; she didn't want to just lay her Note on the desktop at work or home as she wanted to keep using it while charging. We looked at docks but they all were for the naked Note and I didn't like the idea of her needing to pull the device in/out of the case over and over each day. What to do, what to do, well you design and print your own! Over the course of a few days I designed this 3D printable case that allows the Note to charge/sync with the factory adapter, hold the stylus in a readily accessible location and hold the Note while still in a nice leather folding case!
This dock has been designed to print on small build platforms so any home printer should have success printing. The placement of the parts in the stl files attached produce the two dock halves and clip even with less than perfect printer/slicer settings.
You can grab my 3D model here: http://www.123dapp.com/123D-3D-Model/Galaxy-Note-Dock/647399 and use the free 123D app by Autodesk here: http://www.123dapp.com/123d to mod if you like and then export to your preferred format for 3D printing; here is a sample workflow I have used at home designing and printing with great results: https://www.instructables.com/id/Basic-workflow-for-3D-design-in-Sketchup-and-3D-pr/
I also uploaded my finalized stl's for direct use on your 3D printer. Use those if you don't care to mod my design and simply want to slice and start printing.
Instructions:
- Print dock portion A
- Print dock portion B
- Print dock clip
- Insert Samsung factory adapter into front groove of either dock portion
- Push dock A and B together
- Slide clip down into channels
- Plug USB adapter into outlet adapter
- Slam your Note in with or without case!
If you like any of my projects please vote for me in the "Make It Real Challenge" using the vote button in the top right of the page. Thanks a ton for your votes!
Make On!
