My husband and I bought an old play-set for real cheap ($25), the only catch was we had to take it down ourselves. We thought it was not to bad of a deal until we actually got there. The only things worth keeping were the slide($175 new) and the plastic rocks for the wall. They both were still in pretty bad shape though and needed refinishing. So I looked up different spray paint art and found space painting.
Remove these ads by
Signing UpStep 1Supplies
The most expensive item is the ventilation mask which can run you around $20-$30.
Spray paint- I used Krylon Fusion which is made for plastics. Gloss paint is a must.
4-Black
1-Yellow
1-Blue
1-Red
1-White
3-Clear Coat
10 pack of white poster board for practice
Various circular objects They need to have a very thin edge and only the edge must touch the paper when set down. These objects are only going to be used in your practice, Tape with be used on the slide.
Old magazine (needs to have glossy paper)
Disposable gloves
Painters tape, the blue kind works the best.
Exacto knife or rotary cutter
Sand Paper
Steel wool
Paint Thinner
Simple Green (or other heavy duty cleaner)
Tarp or old sheet
2- 2"x4"x6' pressure treated wood
6- 1"x6"x8' pressure treated wood Or 2- 1"x6"x8' and 2- 1"x6"x10'
2- 4"x4"x8' pressure treated wood
1- 9' Rope
1- bag of gravel
2- bolts w/ washers
48- 2" screws
18- 4" screws
Miter Saw
Circular Saw or Jigsaw
Drill with 1/2" bit
Slide
Level
Rock handles
Post hole digger and/or shovel
4
comments
Add Comment
LifeWarrior
says:
acbatman54
says:
scoochmaroo
says:
patriots8888
says:
Add Comment
