Galvanized Plumbing Parts Lamp by rubbit
Featured
Having a reasonably un/healthy obsession with industria and vintage industrial decor, I found it hard to stop thinking about the Kozo lamps by Anat & David Shefa. I just had to have one!!! But budgets being budgets and me being me, there would never have been any other way. I had to just make them myself. So I went down to the local hardware store and grabbed:
5x - 15mm elbows
4x - 15mm male/male spacers
3x - 15mm tee pieces
2x - 15mm x 100mm tube
1x - 15mm x 200mm tube
1x - 15mm x 400mm tube
1x - 15mm female to 20mm female reducer
1x - 20mm male to 25mm male reducer
1x - 25mm elbow
1x - 25mm male to 20mm female reducer
knead it epoxy putty
lamp for parts (i used the cheapest halogen i could buy)
make sure the fitting you're pulling out of the lamp will fit into the elbow to the lamp head
all the assembly is pretty straight forward.
i won't get into all the wiring details. they're pretty straight forward but if you don't know how to do it, i'm not getting blamed when you zap yourself using my instructions!
i had to cut down the length of the 25mm male to 20mm female reducer with an angle grinder so that the fitting would sit nice and snug behind it, all held in place in the big elbow with the knead it epoxy putty.
since photographing this i have added a silver toggle switch in the middle t piece and changed the cord to a silver cloth covered number from sundialwire as white plastic doesn't really do it for me.
i put together a time lapse video of the build at -
http://www.youtube.com/watch?v=oZ2_7CYdlz4
Charlie123456 says: Dec 16, 2011. 4:37 PM
On the 6th line of what you collected at the hardware store did you get 1x - 12mm x 400mm tube or 1x - 15mm x 400mm tube? I want to try and make this lamp but i don't know how a 12mm x 400mm tube fits in. (i assume this is the tube connected to the light)
rubbit (author) says: Dec 17, 2011. 3:59 AM
hi there, sorry that should be 1x (15 x 400)
all the tubing should be the same diameter.
Charlie123456 says: Dec 17, 2011. 12:03 AM
Thank you for sharing how you made this lamp. I have just finished making one and it looks great and was easy to assemble. For anyone planing on making one in Australia, i bought the metal tubing and a transformer with a power cord attached at Bunnings and a light with a cord to attach to the transformer at beacon lighting.
javajunkie1976 says: Jun 5, 2011. 2:49 PM
What's the conversion to the American measurements? If I were to make this, I'd make it out of brass, copper and add a few gear and such. This would be great for a Steampunk project.
alhowell13 says: Jun 10, 2011. 9:37 PM
10mm.=1 inch
hope this helps
rlm98253 says: Jul 7, 2011. 2:46 PM
Sorry, alhowell13, that will not be of much help.
25.4 mm = 1 inch
javajunkie1976 says: Jun 5, 2011. 3:13 PM
Also, how do you run the power cord out of the base of the T-joint? Do you drill the T-joint? I would change the halogen light to a 3watt LED and add a lightshade. The LED will cut down on the power usage and the shade would look nice.
rubbit (author) says: Jun 7, 2011. 2:10 AM
sorry mate, don't know what the conversions to imperial would be. but i wouldn't take the measurements too seriously, they're just there as a rough guide.
if you're after a copper brass one 'mlocke' has a great guide
http://www.instructables.com/id/Desk-lamp-made-from-old-plumbing-bits/
if you check out the youtube link of the time lapse you can see me drilling a hole in the bottom of the centre piece, but it can go anywhere, even out the bottom of one of the feet.
javajunkie1976 says: Jun 7, 2011. 5:55 PM
Cool, thanks. Funny, when I saw your screen name, I thought it said "rabbit." : )
Joobs says: May 27, 2011. 12:12 PM
Does anyone know where you can get this kind of pipe in the UK?
leftfootleashed says: Jun 4, 2011. 2:53 PM
Try Toolstation (usually cheaper) or Screwfix (more choice)
SHIFT! says: Jun 1, 2011. 11:29 AM
This would go great for a Steam Punk Luxo Jr!
neuropol says: Jun 1, 2011. 10:53 AM
Great lamp! The only thing I'd change if I were making it would be to double up the elbows on the stem. That would give more articulation and allow better aiming for the light. That might be getting away from the look you were going for, though. Either way it looks great. Good Job.
CaseyCase says: May 27, 2011. 3:33 PM
"Plumbing."
rubbit (author) says: May 27, 2011. 7:47 PM
fixed....oversight
CaseyCase says: May 27, 2011. 8:13 PM
Hail victory! The spelling Nazi has been appeased!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
