Game Day Potatoes (or any other day) by cmcgann
Featured
These are sliced potato slices that are easy, delicious, and relatively good for you.
Step 1: What you need
This depends on your taste, and the number of people.
Generally, I use the following:
1 medium potato per person plus one extra
three to four tablespoons of olive oil
 Spices; Rosemary, oregano, onion salt, garlic salt, pepper, thyme, ground sage (to taste)
cooking spray
for two potatoes, 1 baking pan
for more, two
Step 2: Preheat the oven
Preheat the oven to 425 degrees.
Step 3: Grease the pan
Grease the pan(s) with the cooking spray.
Step 4: Wash potatoes
I used four potatoes. Wash them thoroughly, since you leave the skin on.
Step 5: Slice
Slice the potatoes into disks between a quarter and an eighth of an inch. Set the slices in the prepared pans. It is okay if they touch or are crowded.
Step 6: Oil them up.
Wash the potatoes in olive oil. Not enough to drown them, but enough to help them cook nicely.
Step 7: Flavor time
Sprinkle the slices with the spices. I use onion salt, garlic salt, pepper, thyme, rosemary, oregano, and ground sage. The amount is up to you, and your taste.
Step 8: Bake
Bake for 21-24 minutes. More or less if you want crispy, but this is a good time for moist, flavorful potatoes.
nancyjaye says: Apr 4, 2012. 8:15 AM
I have made these often and I found dumping the slices in a tea towel and giving them a shake to dry off the sticky starch helps tremendously to prevent sticking...if the potatoes are especially starchy they tend to stick even with olive oil....I have actually rinsed and dried them, then tossed in olive oil....they are worth the effort tho!!
Penolopy Bulnick says: Feb 6, 2012. 11:50 AM
I just love potato slices! It sounds so good! Did you have the issue of them sticking to the pan? I always have that issue.
Josh Galambos says: Feb 9, 2012. 9:45 AM
You Could Place a Bit of Vegetable oil or Olive oil to keep it sticking. Or Butter is another.
cmcgann (author) says: Feb 9, 2012. 10:18 AM
Sure thing. Good thought.
cmcgann (author) says: Feb 6, 2012. 6:50 PM
I use a non-stick spray on the pan, so no.
But if I forget the spray then it becomes an issue.
Josh Galambos says: Feb 10, 2012. 7:14 AM
non sticky pans? That's Good thinking. But It also Brings in Flavor
skiedra says: Feb 7, 2012. 2:23 AM
A great instructable, thanks for posting. I'll try them asap :)
scoochmaroo says: Feb 6, 2012. 11:33 AM
These look delicious!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
