Each kit comes standard with green LEDs, but any LEDs can be used by adjusting the values of the resistors. The board accepts 6 to 12V DC power, and each board draws a maximum of approximately 0.25 amps.
This kit is great for soldering beginners. To learn the basics of soldering check out this great guide by noahw. Also, here's a good video tutorial from the MAKE blog. Bre has a cool video about this on the MAKE blog.
Currently, this guide details basic construction. An explanation for connecting multiple boards will be up soon, too!
Remove these ads by
Signing UpStep 1What you get and what you need.
You may want to check out Dropout Design's own documentation, and print it out. They have a nifty placement diagram as well as a schematic.
What you get:
Board
Atmega48 IC
Regulator
16 Leds
16 Resistors
2 Capacitors
What tools you need:
Rosin core, 60/40 solder
Soldering Iron hopefully with a pencil-like tip
Wire clippers
A vice to hold up the PCB
(You can get all this stuff really cheap at http://www.all-spec.com/ or http://www.allelectronics.com/)
What components you need:
6V-12V power supply
Wire to connect power supply to board
(An easy way is to get a 9V battery with a clip, as pictured)
19
comments
Add Comment
zachninme
says:
zachninme
says:
Nuno
says:
Nuno
says:
Add Comment
