3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Game of Life Kit
Game of Life Kit
The Game of Life Boards are a scalable platform for cellular automata visualizations. Each board contains 16 LEDs in a 4x4 grid, a microcontroller, and a communications and power distribution network. With the available firmware, they execute Conway's Game of Life. Boards can act alone, or can be plugged into other boards to create a larger display. You can get this kit from the MAKE store.
Each kit comes standard with green LEDs, but any LEDs can be used by adjusting the values of the resistors. The board accepts 6 to 12V DC power, and each board draws a maximum of approximately 0.25 amps.
This kit is great for soldering beginners. To learn the basics of soldering check out this great guide by noahw. Also, here's a good video tutorial from the MAKE blog. Bre has a cool video about this on the MAKE blog.
Currently, this guide details basic construction. An explanation for connecting multiple boards will be up soon, too!
Step 1What you get and what you need.
Check out the pictures for what you get with the kit, the tools you'll need, and what extra components you'll need.
You may want to check out Dropout Design's own documentation, and print it out. They have a nifty placement diagram as well as a schematic.
What you get:
Board
Atmega48 IC
Regulator
16 Leds
16 Resistors
2 Capacitors
What tools you need:
Rosin core, 60/40 solder
Soldering Iron hopefully with a pencil-like tip
Wire clippers
A vice to hold up the PCB
(You can get all this stuff really cheap at http://www.all-spec.com/ or http://www.allelectronics.com/)
What components you need:
6V-12V power supply
Wire to connect power supply to board
(An easy way is to get a 9V battery with a clip, as pictured)
19 comments
Apr 13, 2009. 8:34 AMboudemaniak says:
Where can i get the .hex file? i burned the chip and i have another one without the program :) my new chip is the atmega8.. can i use that one?
May 6, 2008. 7:52 AMlifelong-newbie says:
It's a popular kit, but i'd be wary of a craze of manual re-writing going on. There's not much point in going back in time and documenting all the electronics kits ever released. But still a good instructables
Jan 31, 2008. 6:46 PMA good name says:
What does this do?
Apr 7, 2008. 10:15 PMiq_abyss says:
Aug 24, 2007. 10:18 AMarutkow says:
Would it be possible to cover a large sphere (llike a big toy ball from walmart) with these boards, and wire them all together in such a way that there would be no beginning or end? And if so, how tacky would it look as a ceiling light/chandalier in my apartment? -Abram
Sep 15, 2007. 9:22 AMarseny says:
They're flat boards. So you can cover a ball, but it'd look weird. It would look very strange, indeed.
Sep 15, 2007. 8:51 AMtylermenezes says:
What is the size of the board? I'm wondering how many of these I would need to cover something.
Sep 15, 2007. 9:21 AMarseny says:
They're about 3"x3" but that's not exact. Email the Make store, I'd say.
Aug 18, 2007. 7:46 PMarutkow says:
I am curious about the possibilities of combining this project with another one I found online for a Frosted-glass-top table (I assume though that the display would have to be in a square form to look best). I am new to LEDs , but I am confident I could handle the work involved. Unless, of course, the costs start to skyrocket, I think it would be interesting to watch the Game of Life while I am eating dinner, perfect when there is a lull in the conversations. Any advice would be appreciated. -Abram
Mar 24, 2007. 1:47 PMzachninme says:
These boards are interesting, but something bothers me. On the game of life, there are 8 cells surrounding every cell, right. Yet the side inputs only have enough for 16 LEDs. This means, the corner LEDs are not factored in. I don't know how to visually show this, but if you have 4 of these boards, say these numbers represent the led's at the corner: [12|34] 56|78 In this, 2 cannot affect 7, as it has no input onto the board, unless its sent from board-to-board, does it?
May 30, 2007. 7:22 PMtrialex says:
Yep, they have included corners in their algorithm. 2 will affect 7, assuming the board to the right of three and above 7 is in place to take the data and pass it on.
Mar 27, 2007. 7:26 PMfourier says:
Actually, in Conway's Game of life, it assumes the board is infinitely large. Because of realistic boundaries, people attach the edges for a old school space invaders-like movement. You know, where if you go too far left, you come back from the right edge. But this causes interference with other propagating cells.
Mar 30, 2007. 5:47 PMzachninme says:
On that note, I wonder what happens when you connect a board to itself, i.e. the 4 things on the left to the 4 on the right, and 4 on the top to the 4 on the bottom...
Apr 2, 2007. 8:43 PMNuno says:
eh, sorry, not yet ok, "220Ohm Watt Resistor" makes no sense :)
Mar 31, 2007. 10:24 AMNuno says:
Nice project! I think you meant "1/6W" and not "16W" on the resistor comment on the first image.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:MAKEkits
