Gaming/Dining Table From Oak Flooring
Published
Introduction: Gaming/Dining Table From Oak Flooring
About: Basic Crafter. Jack of all master of none
A gaming table that I can also use on a daily basis as a dining table.
Step 1: Planning the Size
To begin the challenge of building my dream dining table I first had to determine the size.
basing most of the design on the dimensions of the floorboards. (1800x19x120mm) I laid them out in a few different patterns finally deciding on the design photographed above. The table top would be 8 boards wide with on board on either end to cap them. Cutting the end pieces to length I used a pocket screw jig to join the 4 outer edges.
Table top dimensions: 960mmx2040mm
Step 2: Gaming Well
I had 2 fabrics to choose from I hope you think I chose well. the well is made from 9mm MDF that I had cut at the store I bought it from. the depth of the well is 70mm. this was covered in the fabric with some quilted padding under it to give a nice bounce to the dice rolled. I added a plastic channel for the RGB strip I planned on adding.
Step 3: Attaching the Well and Electronics
I attached the well with 90deg angles so that the well can be removed and changed to match its surroundings when I decide to decorate again. once it was attached I added boxes for the speakers and added 5050 RGB LED stripping.
Step 4: Legs and Apron
Building the legs together was a simple task using pocket screws on 3 walls and angles in the last. I then cut the apron pieces to size and routed a channel for the aluminium inserts. These will be used for sliding platforms to give extra space for players drinks or dice trays when playing RPGs.
Fun Fact: Most of this table was built while listening to Critical Role.
Step 5: Panels and Final Assembly
The 6 middle boards were joined in 2 groups of 3. Each was drilled in an offset dot pattern. followed by a 15mm Forstner bit to create a recess. a coach bolt was inserted into the recess. A nut and washer were tightened on the other side to keep them in place. On each board, the 3 bolts can lift up giving a hold to remove the panel.
Please if you have any question ask away. I will try to answer them to the fullest of my capability
Step 6: Bonus
With all the Spare boards and offcuts I covered a hideous gas fireplace and added acrylic shelves
Woodworking Contest
This is an entry in the
Woodworking Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    Thank you. Tomatoskins
