3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Garage Climbing Wall
In this instructable I show how I designed and built a climbing wall in my garage for relatively cheap. To view this project and some other pretty cool ones I haven't had time to transcribe over to instructables visit my site mechanicallyinclined.net
Of course every garage varies so my design probably couldn't be copied exactly but hopefully showing how I did will show all the basic concepts behind building a wall and give you a good idea on how to go about this large undertaking should you choose to do so. The total cost of the project was under $400 (that includes holds so if you made your own holds it would be ~220$) and is well worth the investment. An added bonus is the wall has a door that can be opened so it doubles as extra storage space. (or if you dont need storage space but have kids (or you're a kid yourself) you could use the inside as a pretty awesome fort). It really is up to your imagination. But without further adieu we will delve into the finer details of climbing wall design & construction.
Step 1Brainstorm
This is the part that you sit down and decide what you want from your climbing wall and combine that with what you're capable of doing based on space limitations, cost, ability, etc.
After brainstorming I compiled a list of the things I NEEDED my wall to have:
-Large 45 degree overhang for the main climbing area, to be used for strength and endurance training.
-Smaller 90 degree overhang for super intense workouts.
-25 degree lead out from the 90 degree that i could mount a Jacobs ladder to for finger strength training
-A pull up bar
-Access to the inside
And a list of things i WANTED to have:
-A vertical wall just for fun
-A variable angle part
-Some sort of bulge
-Anchors at the top to belay small children
I also instituted a budget of $500 that I didn't want to exceed.
You take all your requirements then go on the the next step DESIGN where you put all this together to make the best wall possible that meets as many of your constraints as possible
50 comments
1-40 of 50next »
Nov 29, 2011. 6:45 AMmAjc0 says:
Hey, I'm just wonder which program are you using for computer design of climbing wall?, Thank's! Have a nice day:),
Feb 22, 2008. 7:39 AMewilhelm says:
Nice work! Did you consider finishing the surface of the plywood in any way?
Apr 25, 2008. 8:30 AMbazookazuz says:
I would not recommend worrying about surface roughness. You will find that home gyms work best with steeper walls (i.e. 30 degrees from vertical or more), and the texture is useless on walls that steep (unless you are Spider Man). Anyways, sticking to the route and not smearing will make you a stronger climber. Save the smearing for outdoors.
Jan 22, 2010. 8:22 AMjusdisgi says:
I agree that there's no need for texture as far as smearing goes. But I'm about to texture-paint my wall (much less extensive an operation than yours) because I keep spinning the holds. Mostly it's big buckets that have the problem...if I do a big reach sometimes I'll just spin them 180 degrees. I can't make them any tighter without pulling the t-nuts through the wall...
Anyway, ewilhelm, if you're looking to texture it the easy way is just to mix paint and sand.
Jan 22, 2010. 11:32 AMbazookazuz says:
If you are only having trouble with a couple of large holds spinning, I would suggest putting small screws in the wall to stop them from rotating. Some large holds have pre-allocated spaces for these screws. Adding a couple of screws is much easier than painting an entire wall. Of course, if your wall is only a couple of panels, the paint may be the easy way to go.
Oct 22, 2011. 1:09 PMfinton says:
I used small ball-bearings to stop our bathroom cupboard handles from rotating. Being only held in by a (usually too-short) screw, they tend to unwind slightly thus allowing the screw to pull out. A bearing about midway between the screw and one corner sinks into both the handle and the door; tighten up the screw, and the handle no longer moves. Better than glue, 'cos you can still remove the handle.
Jun 21, 2011. 6:06 AMsuckrpnch says:
I love the idea. And it illustrates how doable it is to build a climbing wall at home, but at 6' 4", I would be hard to get anything out of this in a 10' space.
Nice idea.
Oct 13, 2011. 1:57 PMwilgubeast says:
Climb laterally and save cash on ropes.
Jun 7, 2011. 12:54 PMapenjong-31295 says:
what i like to do is first place 3 holds. after that i hang in it and make a movement. wherever my hand ends (or just doesn't :p), i place a hold.
Jun 6, 2011. 6:53 PMjames1214 says:
Great intro to climbing comic book for kids is
Betty and the Silver Spider
And when im traveling I search for gyms on www.indoorclimbing.com
Jun 6, 2011. 5:50 PMTangerineBadger says:
This is so awesome! Earmarked for when I have a garage! :-)
Jun 6, 2011. 3:26 PMBiggsy says:
I would LOVE to build one of these in my scout hut... but alas we don't have the space... welldone matey I love it
One of my coveted high fives for you
Apr 2, 2011. 9:08 PMHoneynbennkids says:
As a momma I'm glad to see concerns about safety!
Do you recommend a book or site that teaches how to climb? My children are interested but we're in Ohio and....our "rock wall" was in the mall and they practically pulled the kids up instead of letting them climb. They love to climb trees and such so I was thinking this in our garage...
Thank you for sharing. This was a lovely instructible.
Jun 9, 2010. 1:00 AMstatic says:
I have seen video of one home in the State of LA, who's owners put in a "climbing wall" instead of a stairway to get to the second floor. The entire house is an out of the box off grid home.
Jun 19, 2010. 11:46 PMPoet_rocker says:
I now know where I will live after my eventual graduation.
Jun 15, 2008. 11:27 AMabcparkour says:
good job i wud luv to make a wall like this do u know much about the concret walls my local center has all concret there are only like 4 screw on handholds in the hole place..
Feb 26, 2010. 2:33 AMlasersage says:
that's weird. as concrete can't be removed for cleaning (pressure washing out the old chalk and rubber) then they usually become glazed/polished pretty fast.
Feb 27, 2010. 10:49 AMwillywoozle says:
Makes it just like French limestone then !
Feb 26, 2010. 3:11 PMabcparkour says:
yea one or two holds at the bottom are a bit slippy but it stays pretty rough i think they put sand in it or somthing i dono...but its scheduled for demolition which is a shame it was a rly good wall and ive never seen one like it.
Feb 26, 2010. 3:38 PMquesoman says:
When i get out of college im gonna build a house thats gonna have one central "tower" and two "wings" coming off. in the tower im gonna build a wall like this. GREAT IDEA!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Feb 24, 2008. 1:54 PMfancypenguin845 says:
cool! i had a friend with a treehouse, but instead of a ladder they had a full climbing wall with climbing apparatus to get to the top, then a zipline to another platform across the yard. now i can have one, since i moved, but it will be costly. do u have any tips to lower the cost?
Apr 25, 2008. 8:47 AMbazookazuz says:
If you want to save money, DO NOT buy nuts/bolts/screws from a hardware store!! Go to an industrial nut and bolt supplier (search nut and bolt supply in the phone book) and buy everything in one trip. They will sometime give you %10 discount for buying $100, $200, whatever. I also don't suggest buying super-cheap or super-expensive T-nuts. I saw prices from 6-45 cents a piece when buying 1000. I bought some 6 cent units that had super shallow threads and tended to mess up the threads on the hold bolts if torqued too tightly. After messing up a dozen bolts (@ .50 ea.) I realized that these t-nuts were costing me more than i saved. I went to a different supplier and got some better T-nuts @ 0.12 ea that were great quality! Moral of the story is, expect to pay 0.15 ea for good T-nuts and make sure you get to inspect the product before laying down $150. I use Mack Nut and Bolt in Bryan, TX. They are worth a couple hour drive if you live close to them.
Feb 26, 2010. 2:38 AMlasersage says:
when searching nut and suppliers I've had more luck in the past searching fasteners. When I lived with my parents Suffolk Fasteners sold me all the bolts I ever needed for car and motorbike restoration and climbing stuff. Now my local one is Paramount Fasteners. Maybe this is just an English naming convention but thought it might help on your hunt for quality bolts for less  :)
Nov 27, 2009. 10:32 AMcalvindo says:
 Very cool project.  Great use of space.  Very useful, especially taking the sheetrock out of the ceiling to expose the studs makes it easy.  I'm inspired to get started!
Aug 19, 2008. 1:48 PMgingertech says:
that is the most awesome thing i have seen in ages:) top banana! shame i dont own my own garage being 15 and all but when i get my own house this is what i shall do:)
Aug 17, 2009. 1:53 PMrck_mtn_climber says:
and i made mine when I was 12 : )
Aug 27, 2008. 6:16 PMBigBearHostel says:
Not bad. I built a 20ft tall A-frame wall above the deep end of my pool a few years ago. No belay needed if you can swim. Great spectator sport watching people lose it and fall into the pool. Anyway, I just wanted to say that I easily built some nice holds out of TREX 2x6 decking scraps. Just saw or grind them into hold shapes and you can bolt them up and them feel nice and soft.
Jul 15, 2008. 8:34 PMA good name says:
Just a tip, it should be "Or if you're a kid"
Jul 25, 2008. 9:27 PMA good name says:
Lol sowwy :(
Apr 25, 2008. 7:59 AMbazookazuz says:
Using OSB (the cheaper ply wood) is great, but the T-nuts will fall out all the time unless you glue them in with something like Liquid Nails. Not a big deal if the back is accessible, but a huge pain on a roof section.
Apr 3, 2008. 7:49 PMtoolgal29 says:
just wondering...do u do any other upper body workouts? or did only climbing give u such buff muscles? lol, i really like ur instructable!
Feb 22, 2008. 12:33 PMPyroMaster007 says:
Waaayyyyyy tooo expensive! It looks awsome but sure is costly!
Feb 22, 2008. 1:02 PMtommyh says:
While this wall is very cool and inspires creativity in your climbing, it is possible to build a pretty functional wall for less than $200. I've got a bare bones 45 degree woody that cost me $120 (without holds) and took me 7 hours to build, including the trip to the hardware store.
Feb 22, 2008. 2:47 PMPyroMaster007 says:
Still too expensive...
Mar 1, 2008. 8:56 PMj_man51 says:
As an avid climber, I have to agree with you. I would drop 400 bucks on a personal wall in a second, especially considering a daily bouldering pass at the local rock gym is a good $20. Kudos on the wonderful build! I've made a much smaller "campus" board, but I painted it with a sand- paint mixture to give it the authentic rock look.
1-40 of 50next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
35
Author:swighton(Mechanically Inclined)
I am a mechanical engineering/computer science student. I currently am very interested in engine design and just about anything else. A look at my website will show you how very diverse my tastes are....
more »
