3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Garage Door Does Not Close
It was late in the evening.  My wife had just come home.  The garage door did not want to close when she pressed the button on the remote.  It had worked just fine a few hours earlier.  My tools are in the garage.  Leaving it open all night is not an option.
Step 1Force it to close?
Force it to close?
This is the hard wired switch on the wall.  She was able to make it close by holding the pressure plate on the switch down until it had closed.
14 comments
Feb 29, 2012. 7:47 AMgaragepro says:
The problem that you have is a commend problem. and it's easy to fix it. You problem just need to adjust the sensors. And to make sure that both the lights are turned on. If that don't work and you need more help you and found the manual instruction in this web site.
http://www.burlingtoncountygaragedoors.com/
Dec 15, 2011. 12:24 PMTim Temple says:
The instructions on my garage door say that entropy makes the door stiffer to pull up or down. The motor detects that as a problem and stops the door. Especially when it is getting cool.
Make sure nothing is breaking the electric eye. Disconnect the door from the opener with the lanyard. If the opener operates okay, look for two rheostats on the back of the motor -- one marked "up" and the other marked "down." Give the appropriate rheostat a slight clockwise turn and actuate the opener to reconnect it. That should solve the problem.
Dec 15, 2011. 9:32 AMnubie says:
(removed by author or community request)
Nov 13, 2011. 7:59 AMnwait says:
Hi PhilB
I'm not sure if my comment is in any way related to your problem, but might spare you some hassle later on.
Reading your statement that the door was too heavy and you couldn't let it down manually, means that your torsion springs are unbalanced. This also means that the door is also extremely "heavy" to open. All this relates to excessive loads on the garage door opener, which then can make it register an 'obstruction', making it either return open while closing, or remaining in a half open state while going up.
I suggest you have it seen too, so next time you encounter a contact problem you will be able to operate the door by hand. Easily, as it should be....- Remember, the door opener is there for convenience, not to operate as a weightlifter for faulty balanced doors. This is also unsafe.
Norman - Garage door installer - South Africa
Nov 14, 2011. 3:18 AMnwait says:
Hi Phil
Yes it's possible for them to either have "underwound" the spring, installed the wrong spring in terms of weight to height ratio - springs are manufactured according to the door's weight and opening height ie. lets say your door weigh approx. 160 Kg's, then you would probably have on 2x springs of 90 kg ratio each to lift it up to 2.1m high door opening - this is so that the cables remain taught at opening height and not come off the drums because off becoming too slack. The other factor is that doors need servicing once a year. Springs loose tension as they are under strain while the door are closed, which it is 90% of the time - on average. this means that 90% of it's lifespan it's standing and loosening tension gradually. This needs to be adapted/tightened/serviced yearly. Over progression of time the springs become weak and are unable too lift the door.
Hope this helps.
Norman
Apr 3, 2011. 2:38 PMPoolshark152006 says:
You do realize that you are able to Open and Close the door manually by pulling the red string buy the garage door motor...
Apr 3, 2011. 9:47 PMPoolshark152006 says:
My response thought was you would be able to pull down for the night, then fix it in the morning...
Apr 1, 2011. 5:08 PMrimar2000 says:
Bravo, Phil. Most electronic and electrical failures are due to problems of contacts, especially in areas of low voltage circuit. My microwave oven has over 15 years, and I had to gut it twice to clean the contacts. It's amazing how always something rust, or sulfate, or dirty.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
475
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
