3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Garage Door Open Indicator Light
This Instructable will explain how to make a simple flashing LED indicator to let you know when your garage door is open.
At the end of the day I was always checking the overhead garage door on my house to make sure it was closed.  I decided to install a flashing LED light that would let me know when it was open.  This has saved me many trips down the steps from upstairs to check the garage door before going to bed at night.
Step 1Tools and Materials
Tools and Materials
Materials
  1. Blinking red LED from Radio Shack.
  2. SPDT Switch with 3/4" Roller Lever from Radio Shack.
  3. Miscellaneous DC Wall transformer.
  4. A resistor for the LED.
  5. A piece of scrap aluminum.
  6. Miscellaneous wood screws and machine screws as needed.
  7. Miscellaneous two conductor light gauge wire.
Tools
The tools I used on the project were as follows:
  1. Cordless drill
  2. Screwdrivers
  3. Hacksaw to cut aluminum material for brackets
NOTE: If you plan on using any tool for a project please make sure you are familiar with the tool and all of the dangers associated with it. If you are not familiar with a tool then you should ask someone who is to show you the proper way to use it. A lot of communities have classes at local colleges on the proper use of tools and machinery. There are also local woodworking clubs that offer classes at very reasonable rates for beginners. I highly recommend using these resources for your safety and for the most efficient use of the tool.
SAFETY FIRST
Always wear eye and hearing protection.
Always work safe with the proper safety equipment and guards on your tools.
25 comments
Dec 15, 2011. 10:58 AMphilspitler says:
I'm on the third floor and would love to figure out a wireless solution.
Any thoughts?
Dec 22, 2011. 8:28 AMCoyoteTeacher says:
I use X10 senders/receivers with magnetic reed switches (two-door garage), so there are no batteries and I can put the receiver in the appropriate spot. X10 is still available on-line and inexpensive.
Dec 19, 2011. 11:05 AMBrockman512 says:
Craftsman Wireless Garage Door Monitor
http://www.sears.com/shc/s/p_10153_12605_00953696000P?prdNo=1&blockNo=1&blockType=G1
Other types are available. Check your local home supply store.
Dec 16, 2011. 3:08 AMMadrigorne says:
you might be able to piggyback this led/switch off the power that runs to your wall switch or the saftety beams on your garage door opener
Dec 15, 2011. 7:15 PMgcai_fwb says:
very good instructable
I made a similar indicator circuit using a doorbell switch with an internal light - this was way before LEDs were widely available (at least to me) about 30 years ago - a little bit of switch disassembly and rewiring it to make the light independent of the switch.
The doorbell switch now activates the garage door opener and the light comes on when the door opens - whole thing runs off the existing door bell transformer using repurposed 4 conductor telephone corded.
I have 2 of these modified switches - one by the front door and one by the rear allowing me to open and monitor the garage door from either spot.
Maybe I'll update to use LEDs :-)
Dec 13, 2011. 6:50 AMadillbeck says:
I did something really similar to this.
Couple differences; I used magnetic reed switches instead of a physical switch because I was a little afraid that snow would get into the switch in the winter and freeze it solid. And also I wasn't sure about how the roller bit on the switch would handle the joints on the door.
I didn't have any normal wire for this either, so I pulled individual pairs of wire out of a Cat5 cable that had been chewed up by the cat.
And lastly since I don't have any easy power sources in my garage, I run mine off of a 9v battery. I put a second LED on the circuit inside of the garage so that I could double check that the battery hadn't gone dead before I shut the garage door.
Dec 15, 2011. 1:39 PMAnimattersInc says:
CAT5 chewed up by the cat. LOL
Thanks for the instructable. I'd seen another one similar on here but never got around to it. You may have motivated me to get it built this time around.
Dec 15, 2011. 12:56 PMCherylb1003 says:
I've read so many cool instructables, but never actually done one. Little skill, inexpensive supplies, really clear instructions, this one is for me!
I'm in the habit of closing the garage door when I come in, but sometimes I leave it open for hubby or go out the garage and come into the house from the deck after doing yardwork. Next morning, I'll see that anyone could have come in and entered the house overnight.
As it's a safe neighborhood (and nothing exciting happened overnite), I'm more worried about a small animal coming in during a cold evening and getting under the hood and next to a comfy warm engine - I would not want to see, or hear, the results if I turned on the engine under those circumstances!
Dec 14, 2011. 6:28 AMwiltech says:
Could I just piggyback onto the same transformer that is used for my doorbell ?
Dec 15, 2011. 12:18 PMdiy_bloke says:
Most likely you could, as long as it is the secundary voltage that is used by the knob of yr doorbell (it most likely is).
See the doorbell transformer just as a PSU with the doorbell attached as one circuit and now u r using that same psu for another circuit.
Just make sure you go parallel with the bell, not in series
Dec 15, 2011. 12:12 PMTim Temple says:
How about a transparent plastic stirring rod driven through the whole wall? Or am I just being a killjoy?
Dec 15, 2011. 6:34 AMgrabaclue says:
This is a fantastic idea! Every night, I open the door from the house to the garage to make sure the garage door is closed before I set the alarm for the night. This is a perfect solution that I will definitely try myself. Thanks!
Dec 13, 2011. 8:55 AMChanio says:
Nice project!
For powering the system perhaps buying a solar garden light you could get solar power and a led all at the same time...
Dec 13, 2011. 7:57 AMslevy951 says:
What size resistor?
Also, for 2 garage doors, just add another switch in parallel, right?
Dec 13, 2011. 9:01 AMadillbeck says:
Yeah. I have two doors, and have both switches on the same circuit so that if either switch closes it turns the light on.
Resister depends on the output of your power source and how much resistance is on the line. On a 9v power source (a battery in my case) and with two LEDs in the circuit, I believe I have a 270 ohm resister. If I'm remembering correctly.
Do a little reading on Ohm's law. It's not to complicated, and every setup will potentially be different, and so need a different resister.
Dec 12, 2011. 7:55 PMhijodelsol says:
You could use a magnetic switch which would be easier to set up.
Dec 12, 2011. 5:24 PMckokosa says:
Awesome idea. I think I'll locate the LED by my thermostat. I can use the 2 spare wires that go from my furnace (in the garage) to my thermostat.
Dec 12, 2011. 3:55 PMveggiemaster says:
Simple and extremely functional. I find myself going downstairs almost twice every night before bed to REALLY be sure that the garage is closed.
I would guess that nearly 90% of all instructables members could do this without having to go buy anything. Im wondering why I didnt think of this sooner!
Props to you!
Dec 12, 2011. 12:20 PMj1shalack says:
Excellent!
Dec 11, 2011. 1:03 PMkooth says:
Very cool: I was looking for just this kind of solution for my garage! Great job and thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
50
Author:stevemoseley
