Garage Door Opener and Camera
1,879
17
4
Published
Introduction: Garage Door Opener and Camera
My project uses Arduino Mega 2560, distance collision avoidance sensor, echo distance sensor, relay switches, RTC clock, and wired connection to the garage door opener. I can monitor the status of the garage door, view video camera, open/close the door, auto close the door after specified timer, etc. It serves as a web server. It has been stable for about two years. Arduino sketches enhanced to detect the changes in IP address, check and adjust time, using external PHP server which is not available to Arduino, etc.
The 13 files are uploaded.
Step 1: Parts Needed (around $60)
8 GB micro sd card for storing web server files. 4GB will do. There are not many files.
Ultrasonic Module HC-SR04 Distance Measuring Ranging Transducer Sensor
$1.93
Ethernet Shield Module W5100 Micro SD Card Slot For Arduino UNO MEGA
$7.35
5V 4 Channel Relay Module For Arduino PIC ARM DSP AVR MSP430 Blue
$4.00
DS3231 AT24C32 IIC High Precision Real Time Clock Module For Arduino
$1.84
Mega2560 R3 ATmega2560-16AU Control Board With USB Cable For Arduino
$9.49
Infrared Obstacle Avoidance Sensor For Arduino Smart Car Robot
$1.96
Test Develop DIY 830 Point Solderless PCB Bread Board For MB-102 MB102 $3.55, power supply (5V) and 120Pcs 20cm Color Breadboard Jumper Cable Wire Combination For Arduino $4.35
optional: 4 Channel Wireless RF Remote Control Transmitter Receiver Module
I use it as a remote control. The RF signals are sent to the Mega 2560 to trigger relay to open/close the garage door. $3.45
I bought mine from http://www.banggood.com/ but you should shop around. Take longer to wait but it's cheaper.
Step 2: Wiring All Together
To be done later.
Step 3: Arduino Mega2560 Sketches Outline
Here is the main menu. Quite a few you don't need. I crossed a few of them. Only four left.
1. Current Garage Door Status:
Using the two sensors, ultrasonic distance measuring and Infrared Obstacle Avoidance Sensor to determine the distance of the top panel of the garage door. If it is less than XX inches then the garage door is open, else the door must be closed.
2. Open or close double garage door 3
I have two garage doors to control. This is the main one. Click to open or close. It requires security pass code to enable the button. You will need an external web server that can execute php codes.
3. Disable auto close timer (will not automatically close)
Used for opening garage door for extending period of time. It will not close when timer (7 minutes) is up.
4. Rest auto close timer to default 7 minutes
When the garage door is open for 7 minutes it will close without warning.
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    4 Comments
    Hi, AndyW11!
    It's so cool instructable.
    I'm an engineer worked at WIZnet provides ethernet chips - W5x00 - to Arduino for ethernet shiled. Your instructable are very helpful for wiznet chip solution.
    Would I like to introduce your instructable on WIZnet museum site(http://wiznetmuseum.com). Can I?
    Thank in advance!!!
    Thanks. I will have to do it a little bit later. Including parts, wiring, and Arduino sketches.
    please share the step by step process and explain how you made this. I m very much excited to know
    This looks like a great project!
    If you added a bit of information regarding how to assemble of all the components, that would be very helpful. Just a thought! :)
