But how is the garage door able to open with a large flat board mounted to it? We figured it out so we are sharing it with you.
We didn't have a garage door opener, so we didn't have to factor it into the design. If you do have a garage door opener, check its rating to make sure it can pick up the door and all the hardware you'll be adding to it. Also, you may have to modify the design slightly to allow for the opener mechanics.
Remove these ads by
Signing UpStep 1Get Materials and Tools
- a garage door, any size will do - we used one a little wider than 8' and more than greater than 4' tall. You just will have to cut your whiteboard down to size if the door is smaller than 4'x8'.
- a 4'x8' sheet of tile board. We got ours for about 13 bucks at Home Depot.
- a 4'x8' sheet of Eucaboard or some other cheap paneling. This acts as a backer for the tile board and makes the entire thing stiffer.
- four 2"x2"8' pine boards. This acts as the frame.
- two 4' lengths of 1/2" threaded rod
- two eye bolts with 1/2" threaded portion
- four nuts for the threaded rod
- two connectors for threaded rod
- two ~3' lengths of PVC pipe large enough for the threaded rod to slide into easily. The closer the fit, the better.
- four metal pipe mounting brackets
- two large lag bolts
- two nuts that will easily fit over the lag bolts
- two large washers that will fit the lag bolts
- a box of wood screws
- a box of self-tapping screws
- four metal hinges
- 2'x4' scraps. We used two blocks about 4 inches long.
- wood glue
- drill, drill bits, drivers
I hope you dont take my comment the wrong way, I absolutely love the idea and the 'ible on it. I just have the burden of knowledge in this particular area. Just know its gonna cost you a couple hundred bucks (or more) to have someone come out and replace that bad boy.
