3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Garage Monitor 3001 Paging System
Step 3Monitoring Script
Monitoring Script
This is the script I use to monitor the garage, which will grab the page, and insert the status in the database.
#Script to enter garage status in DB
#Joe McManus 2010/01/26
#who mail should go to
$mailto="joe@example.com";
#who mail comes from
$mailfrom="garagemon@example.com";
#set the time
$now=date('Y-m-d H:i');
#web status  url
$garageurl="pink.example.com/garagemon-text.html";
#public url to include in page to check status online
$puburl="http://www.example.com/garage.php";
function connect(&$db){
  $db = mysql_pconnect("localhost", "garage", "monitor");
  if ( mysql_select_db("garagemon", $db)) {
        } else {
        echo "Sorry we are currently experiences technical issues. We'll be back shortly.";
        exit;
connect($db);
#check the page
system("curl $garageurl -o /tmp/garage.txt", $retval);
if ($retval == 1 ) {
        echo "Error: Unable to reach web server";
        exit;
#Get the door status
$overhead=exec('grep Overhead /tmp/garage.txt | cut -d" " -f2');
$side=exec('grep Side /tmp/garage.txt | cut -d" " -f2');
#insert the side door in to the db
$insert="insert into status(id, date, door, status)";
$insert.="values('', now(), 'side', '$side')";
$result=mysql_query($insert, $db);
#insert the overhead door in to the db
$insert.="values('', now(), 'overhead', '$overhead')";
echo "Overhead: $overhead ";
echo "Side: $side ";
#Query for doors being open 10 minutes or more.
$query='select date, door, status from status where status="Open" and date > date_sub(now(), interval 10 minute)';
$result=mysql_query($query, $db);
$rowcount=mysql_num_rows($result);
$mailfile="/tmp/garagemail.txt";
if ($rowcount >= 2) {
        echo "Alert: Door Open ";
        //Message start
        $mailsubject="Alert: Garage Door Open $now";
        $mailmsg="The Garage Monitor 3001 has detected that a door has been open for more than 10 minutes. $now ";
        $mailmsg.="$puburl ";
        if(file_exists($mailfile)) {
                echo "Mail not being sent $mailfile exists ";
        } else {
                mail($mailto, $mailsubject, $mailmsg);
                exec("/bin/touch $mailfile");
} else {
                echo "Alert: Garage Door Closed $now";
                $mailsubject="Alert: Garage Door Closed";
                $mailmsg="The Garage Monitor 3001 has detected that a door has been closed. $now ";
                exec("/bin/rm $mailfile");
#Just a query for debugging
$query='select date, door, status from status where date > date_sub(now(), interval 10 minute)';
echo  "door    | status  | date ";
while($row=mysql_fetch_row($result)) {
        echo "$row[0] | $row[1] | $row[2] ";
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
102
Author:joe
I like to tinker with just about anything, sometimes it works out in the end. Have fun looking at the projects, try tearing something open and let me know how it goes. cheers, -Joe
