Step 2Rubber Glove CO2 Trap
Just a regular five gallon jug that drinking water comes in.
A rubber glove is held over the neck of the jug with rubber bands.
The CO2 from fermentation puffs up the glove.
The rubber bands should be just tight enough to hold it on there.
If the glove overinflates the gas should leak out around the wrist of the glove.
I put the glass head over the glove because I didn't know where else to put it.
Also it sends the artistic message "This stuff messes with your brain".
A balloon or even a plastic bag works just as well as a vapor trap but doesn't look nearly as cool.
You could also go to a brewer's supply store and buy vapor traps, but then you wouldn't be reading instructables. Please read a beer brewing book especially about the hazards. Many people are killed by bad homebrews containing botulism etc., so you do need to follow certain sterilization procedures.
The jug contains Kombucha - this photo is from an experiment to make Kombucha with a higher alcohol content. It ended up not tasting as good as the regular stuff, but the fermenter worked great.
If it's apple cider vinegar you can use it for cooking; it's much stronger than what you'll buy in the grocery store. But you're not going to be visiting the land of the homemade buzz.
