Garbage Can Turkey Smoker
How to build a reusable BBQ smoker from a garbage can and an electric hot plate, and then use that to smoke a whole turkey.
Step 1Build a grating support inside the garbage can
build a grating support inside the garbage can
First, get a garbage can and a circular grill grating (usually sold as an accessory to a weber grill). Larger is generally better for both, but the only real requirement is that the can is larger in diameter than the circular grating you will use to put the turkey on, at a level low enough to fit the turkey.
Next, you need to build supports for the grating. Using a 3/8" drill bit, drill three holes approximately 8" below the top of the garbage can, equidistantly placed around the circumference of the can. Then slide three 3" x 3/8" bolts through those holes and secure with a corresponding washer and nut. This will be used to hold the grating up while allowing the grating to be easily removed.
41 comments
1-40 of 41next »
Sep 3, 2011. 5:49 PMKateinNH says:
With old grills, from the classic round Weber to old gas grills available at just about every other yard sale or junk shop, or on Craigslist, I don't think there's any need to risk your health "making" a smoker out of something not intended for food preparation.
Not only that, but there really is nothing sustainable about going to the local HD and buying a brand new garbage can to make a homey-style smoker. The idea is kind of neat, but the fact is that these inventions came out of poverty, not because someone said, "Hey cool! Let's go buy a garbage can make a smoker!"
I've got two Weber grills and I didn't pay more than ten bucks for either one. One is a medium sized one and the other is a classic red extra-large one enough for a party. Any container can be converted into a smoker, but why not start with something made to withstand high heat and that has some ventilation holes and go from there?
Also, buying used is the most sustainable and real way to "keep it local" and keep more things out of the waste stream and back into service.
Aug 29, 2011. 5:02 PMjavajunkie1976 says:
Folks, give him a break. He may or may not be actually using it. He may have a similar smoker made from the proper materials nearby. I do this all the time. I make something from cheap materials as a test then make the real thing out of the correct materials once the design is worked out.
Jun 13, 2011. 5:11 AMCrackersouth says:
Galvanized anything........ BAD idea !!!!!!!
May 29, 2011. 10:42 AMMakedo says:
I see some people know metallurgy which is a good thing.
Jul 22, 2010. 1:12 PMReagenWard says:
My hardware store sells bullet-style smokers for $30. Not so sure this is a deal...
Oct 30, 2008. 7:04 PMbruce226 says:
Way to go! You taught everyone how to give themselves zinc/galvinized poisoning for the holidays! Yummy!
Nov 11, 2009. 8:59 AMjdyeara says:
Hey dumbass! Use a non galvanized garbage can!  Except in your case, use the galvanized one so there's one less dumbass in the world!
Nov 30, 2008. 1:38 PMBearGFR says:
To be concerned about zinc contamination using this method you'd have to do one of two things: 1) Get the temp up to around 1688 degrees F, the boiling/vaporization point of zinc, and then stand there and breathe the fumes, or 2) Run a grinder, welder, or other abrasive tool inside the can while cooking such that zinc shavings get into the food. So unless you do something really dumb while cooking, zinc contamination isn't going to be a problem. Besides, the FDA recommend daily consumption of about 8-11 mg of zinc anyway. One thing you don't want to do is weld galvanized material in a confined space, because that DOES generate enough heat to vaporize it and while ingesting very small amounts of zinc in solid form is ok (even recommended), breathing the stuff in gaseous form is definitely bad news - its called heavy metal poisoning and it can kill you. Like with lots of things, getting zinc in you isn't always bad and its not always good. Its a question of how much and in what form.
Oct 26, 2009. 6:20 PMSergei- says:
The melting point of zinc is 787.15 F
After that you have a pile of goo - why don't people look things up
The bin is galvinized so other things might be added to it aswell like lead since it wasn't meant to cook anything but just for rubbish.
Here's a quote from wiki:
The process of hot-dip galvanizing results in a metallurgical bond between zinc and steel with a series of distinct iron-zinc alloys. The resulting coated steel can be used in much the same way as uncoated. Galvanized steel can be welded; however, one must exercise caution around the resulting zinc fumes. Galvanized steel is suitable for high-temperature applications of up to 392 °F (200 °C).
So unless your planing on keeping the temp below about 350 F your most likely not going to get to your next thanks giving dinner. All my smokers can reach that easy and if your thermometer is faulty watch out.
Try using a beer keg it's out of of 304 food grade steel i made one of those and it can fit a turkey and am going to make a drum smoker out of 316 stainless aswell soon
Nov 14, 2011. 2:47 PMdrawe21 says:
I do, and he has a good point. That is it has to be really hot and shouldn't present a problem for zinc.
http://www.chemicalelements.com
Symbol: Zn
Atomic Number: 30
Atomic Mass: 65.39 amu
Melting Point: 419.58 °C (692.73 K, 787.24396 °F)
Boiling Point: 907.0 °C (1180.15 K, 1664.6 °F)
Number of Protons/Electrons: 30
Number of Neutrons: 35
Symbol: Pb
Atomic Number: 82
Atomic Mass: 207.2 amu
Melting Point: 327.5 °C (600.65 K, 621.5 °F)
Boiling Point: 1740.0 °C (2013.15 K, 3164.0 °F)
Number of Protons/Electrons: 82
Number of Neutrons: 125
Nov 15, 2011. 4:38 AMSergei- says:
Wow
commented over 2 years ago on this
Why shouldn't you drink the rain water collected from a zinc coated garage roof
Even if it's not going going to get hot to the point of melting in the sun fine particals of the coating will come off and same goes for any type of zinc coated cheap rubbish bin - because it's not food grade people since things like this can easily contaminate the food but who knows you might be lacking zinc in your daily diet then go for it
Serg
Dec 19, 2008. 11:32 AMHog1 says:
You might want to pick up an electric fry pan they cost about $20 and you can put it in so the thermostat is on the outside of the can ,and you can put your chips rite in the pan,much cleaner look
Nov 29, 2006. 11:23 AMindyguy says:
It looks like you stole this idea from the Food Network guy Alton Brown. He has had this idea for quite a awhile. He uses the hot plate and everything. I have to say though the trash can is a better idea; he uses a cardboard box! Nice instructable over all.
Jul 6, 2008. 10:04 AMbigcat says:
I've done this when I was in the Boy Scouts, 20 years ago, so did Alton originally steal this from them?? There are so many ways of cooking using everyday materials, some are bound to make their way onto television. You could even wrap food in aluminum foil, and place it on your hot car engine to cook food, which was featured in "Home Improvement" one time!! This is a good idea, one alternative is to use a long stick, mount the turkey on it that way, then flip the can over it. There's no need for a grate, or lid, as the ground acts as the lid.
Apr 23, 2008. 4:26 PMPoppa Chubby says:
Alton Brown is just the latest in a long line of people to use this, or a similar, idea. People have been using garbage cans, 50 gallon drums, old water heater tanks, propane tanks, and hot plates for years and years. The best I saw was 30+ years ago using a large and a small can, connected by a pipe, and the whole thing buried in a small hill.
Dec 1, 2006. 5:29 AMjess says:
Cardboard box smokers are really more appropriate for cold smoking (like fish or cheese) - and although when I built one I felt much indebted to Alton's instructions, I also found that a few modifications (like a second box for the woodchips, and a dryer hose to connect them) really helped. One of these days I'll write that instructable.
Apr 17, 2008. 7:50 PMdirtysteak says:
Pictures (the add images wasn't working, so its just links for now):
my painted version
Bottom
Grates in the "smoker" position
Jun 16, 2008. 10:22 AMcheesalicious says:
Your smoker looks excellent! The door is a great addition. How did you cut through the garbage can material? It looks pretty sturdy.
Jan 6, 2008. 9:08 AMsrteach says:
Mounting or placing the can on a flat metal plate (or with the edges turned up) in an inverted position would simplify the replacement of the chips. Build a rack for the turkey that fits under the inverted can. Make a handle for the top (inverted bottom), place the thermometer in the top (inverted bottom). Lifting the can will allow easier one person access, keep heat and smoke (don't have to remove the entire can body). Smoke flow can be increased with a 1/2 inch or smaller hole in the top (inverted bottom) of the can, and an even smaller hole by the chip plate/burner. A damper on the lower hole can be used to control heat loss. @radarguy... smoking ribs is the same process. Soaking the chips and brining is essential. You can add liquid smoke during brining, though I don't. Brining formula are available on the internet. You can brine quicker with a vacuum machine (3hrs vs. 9hrs).
Nov 28, 2007. 6:19 AMSecondSun says:
sweet.
Nov 22, 2007. 9:20 AMlaernmoer says:
I'm curious about the brine soak - do you refrigerate it while soaking? you don't mention that. If not, is it because the salt will help prevent bacteria growth? It seems slightly unhealthy to me.
Nov 23, 2007. 12:37 AMPhoghat says:
If it is cool outside (less than 50 F) you can leave the turkey in the brine with some sort of cover, out doors. YES it's safer to refrigerate the whole thing, but I saw something similar on Foodnetwork.com from Good Eats that explained the whole thing.
Nov 22, 2007. 7:24 AMradarguy says:
A very nice job! I enjoyed each and every step. I am looking forward to trying this. I think I would figure a removable window along side the chips tray so that I could pull out the tray to change the chips. It may take running the all-thread all the way across the can. Next can you tell us how to smoke ribs? Yummm!!!
Jun 19, 2007. 1:39 PMjuandela says:
nice instructable..... i have a couple of questions: 1) where do you find a hot plate for $10? 2) is there a wattage that is ideal? 3) do you worry about the plastic chassis of the hot plate getting to hot or melting? how about the cord? i had thought about feeding the cord through a small amount of pipe which would exit through the whole in the side of the can. not sure if we're talking about enough heat to even worry. i lucked out and found a char-broil non-electric smoker on ebay for 17 bucks. i drove a half an hour to pick it up and now am contemplating adding the hot plate to make it electric. i'm a couple steps ahead because the side access door is already there as are all the racks, mounts and water/wood pan. i think i've seen the website that you based your instructable on but the beauty of what you've done here is that there's an open forum with which questions like these can be addressed. well done.
Nov 29, 2006. 5:32 AMspinach_dip says:
Wow, pretty cool.
The one thing that bothers me (as a welder) is that all the metal hardware used here except for the grill rack itself is zinc plated. I'm constantly on the lookout for zinc fume fever, but this may be OK here because you are not using actual fire, nor allowing the food to contact the sides.
Anyway, here's an case of do-it-youself zinc fume fever, although an extreme one. Keep in mind that exposure is clumative.
http://www.anvilfire.com/iForge/tutor/safety3/index.htm
Dec 13, 2006. 6:04 PMfishbuster says:
Solution to the zinc coating inside. Start a small oak or other hardwood fire inside the can and let it burn the zinc off. If you do this a couple of times wiping it out it works well. You then coat the inside of the can with a light coating of vegetable oil and run it a while as a smoker w/o the woodchips just heat to "bake" in the oil so the inside does not rust. The other option is after burning it hold it over a fire and smoke the inside of the barrel for rust proofing. I know campers who bake turkeys using the same can as an oven and this is the way they avoid zinc poisoning and make sure the can is free of any other chemical contamination.
Nov 29, 2006. 11:37 PMtrebuchet03 says:
Water boils at 212F -- but it takes much less than that for water vapor to form ;)
Other than zinc, hexavalent chromium is sometimes used as an anti corrosion coating (another thing you don't want to eat :P). Not to mention, if there's a weld seam, you risk other potential nasties from that. You're best bet is to cook the crap out of the can before using it the first time to remove any coating ;) The general consensus is that you'll probably be okay - but who wants collateral damage from their holiday meal? Technically, fish from the Everglades is okay (except for high mercury levels o.0)
We used to do something similar when I was a little kid in boy scouts :P It's a whole lot of fun - probably because of the novelty factor :P
Nov 29, 2006. 8:04 AMCementTruck says:
Good instructable, but I had the same fears. I think a "BRAND NEW" (not used) metal 50 gallon drum would work best.
Dec 1, 2006. 2:45 AMjess says:
The person who's made my past barrel smokers has also used former corn syrup barrels. Great, if you can find 'em - the first smoke is AWESOME.
Feb 3, 2007. 8:40 AMKayakJack says:
Jess, Your corn syrup barrel comment reminds me of a semi-related joke. A small town in Indiana couldn't afford a real fire engine, so they converted an old fuel delivery truck. The first two fires were real Doozies! While the size and shape of a garbage can is handy, its makeup is unnecessarily dangerous. Personally, I'd rather build a tall box out of plywood, drill holes through the side, and run wooden dowels through for racks, make air inlet and exhaust holes, and use an electric frying pan. Air flow can be adjusted by sliding a chuck of plywood back and forth over the exhaust hole in the box top. To each his own, ehh?
Nov 29, 2006. 10:05 AMspinach_dip says:
"brand new" is still zinc plated
Nov 29, 2006. 5:41 AMspinach_dip says:
Someone on that page suggests soaking the metal in muriatic acid (paint department, at the hardware store) overnight (to remove the zinc) and then then rinsing with water. Once that was done prehaps you could coat it with BBQ grill paint?
Dec 12, 2006. 3:58 AMDrackar says:
Mmm. What composite metals is that trash can made out of? And do I see the shine of zink? enjoy your unsafe exsposures!
Nov 29, 2006. 5:24 PMsilliou says:
This is just an idea, but with a small amount of wielding you could actually make the chip tray removable without having to pull the whole thing apart. if you cut a rectangle out of the side just above your heating element, wield in a slider (similar to a drawer), wield the chip pan to the rectangle you removed, add a handle and slide in and out.....
Nov 29, 2006. 4:56 AMTool Using Animal says:
Good call on not stuffing the turkey, in fact, for anyone who tries this, NEVER stuff the turkey. Stuffing cooked for 5+ hours in a smoker would qualify as hazardous waste. Did you truss the bird? I think It'd benefit the final presentation
Nov 29, 2006. 2:06 AMwyrm says:
Very nice instructable! Let's see if I can remember this in about 11 months so that I can set up to try it myself.
1-40 of 41next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:drEel
